One thing you guys are not accounting for, is that lower gears (more gear reduction) is not as efficient.
There must be a reason
@Doubeleive says he lost some top end, I don't doubt him.
I'm not saying that's THE reason, peak engine torque/horsepower rpms may play a factor as well.
There's always tradeoffs..
I will say, for cruising around, when I had a more aggressive tune (that I was initally super happy about)...
.. the constant rpms winding up got tiring, for the speed I was going..
Granted a lower gear would allow you to have more torque at low rpms, so should be better in that regard..
But you'll be shifting sooner, and possibly have an extra shift..
For example I used to cruise in 4th 80% of the time, but now I'm between 4th AND 5th 80% of the time.
I could raise 5th (and might) but then my cruising rpms aren't as comfy..
And with the factory tune, power delivery and throttle position aren't linear, and at light throttle and high rpms, you tend to slow back down..
So now there's more accelerator modulation going on...
Tune it you say! Well maybe, but sometimes the more I change things, the more things need re-tuning!
And actually changing accel pedal position vs throttle position can put you in REP mode pretty easily..
There is a work around I've heard, but it's more involving than just changing one map.
