Atrevino0497
I don’t remember which of you clowns mentioned that little plastic clip on the door handles. I swear it was the next day I pulled up on the outside handle on my right rear door and felt something pop off. The handle quit working from outside. It’s the door my dog uses to get in and out. Today it finally was nice outside so I opened it up and that damn thing had popped off the rod. I snapped it back on and am left wondering if my visiting the forum was the reason I knew how to fix it or the reason it popped off because that’s one helluva coincidence. So maybe quit this talk about cracking dashes for gods sake. :p :p:pView attachment 479496
I had my whole passenger handle pop off this winter. The inside screws gave loose and the base snapped off on the inside. I was not a happy camper. Used a Dorman one and noticed my yellow clamp was broken too so I did exactly what you did. Zip tied to the rescue and all was good again
This seems to be the year for pulling off door handles. I just replaced my rear passenger side door handle earlier this week.
mikez71
Noticed no park lamps on left side, one tail bulb was out, fuse blown.
Old bulbs were about a year old, sylvania long life my ass!
Old bulb has dark spot, heat discolored the plug a little.. no obvious break in filament..
Swore I'd never buy sylvania again..
(LED taillights, dim, total crap. LED interior lights, ugly geen/blue color temp. Long life bulbs, don't last long at all!)
Go to Oreilly's, guess what the only bulb there? Syl-*****-vania..
Spent $37 for 25 15A fuses($13) and 2 tailbulbs. Guess I spent $20 on a pack of 2 bulbs!
-- DO NOT BUY SYLVANIA! ---- YOU WILL REGRET IT! --
Noticed no park lamps on left side, one taillight was out, fuse blown.
Spent $37 for 25 15A fuses and 2 tailbulbs.
if they have the error free led's at this Auxito store then they will have the resistor built in and you will not have hyperflash, led's do not produce the same heat as incandescent and won't burn up the connector. Beware of fake auxito this store is the real one.
mikez71
I have/tried auxito brake lights, what I don't like about them is, when you step on the brake, they hardly get any brighter..
I worried someone won't notice I'm braking.. Also the bright red light washed out the backup camera view.
I am running auxito LED headlights, no issues so far. Decent, reasonably priced upgrade.
But I'm trying HID once I get new housings. (want better dispersion and cutoff)
If anyone wants auxito brake lights and sylvania LED brake, reverse, and marker lights... I'll sell em cheap..
But I'm trying HID once I get around to new housings.
If anyone wants auxito brake lights and sylvania revo LED's and marker lights, I'll sell em to ya cheap!
interesting, I went from oem to k2 escalade style, otherwise I would probably be using aftermarket full led housings of some variety
was hearing a strange noise on the passenger side the last few days, kind of sounded like maybe a bad rear axle bearing, did a cursory check the other day with no real synopsis other than maybe the front brake pads were the culprit, they were about 2/3's worn out so I replaced them a little bit ago and walla noise gone. Also found one of the front splash guard bolts was missing and the thread is of course no good so I drilled a oblong hole on that side and put a worm clamp thru it and around the front bumper support, snug as a bug in a rug now
YukonGold12
replaced the U joints yesterday on my 07 with 220k miles. No more vibrations at highway speed. Love it when things get fixed.
Pulling apart the valley cover today because it’s leaking oil. The bolts didn’t even have resistance when coming out I guess that’s why. Trying to figure out how to replace the gasket on the riveted cover. Posted here about it. https://www.tahoeyukonforum.com/threads/vlom-gasket.157926/
guy from norcal
What did I do? I drove my Yukon over the weekend...
...for the first time since 12/9/25, the day before I fell and ruptured my quad tendon. Now that I can bend my knee 90 degrees, I was able to just work the pedals with the seat all the way back and the pedals all the way forward.
It was glorious!
Ouch! Sounds like it was a good day.
Sir_Hiro
Automotive Mad Scientist
Drivers side rear brake caliber is sticking..ofc its right after i put brand new powerstop pads on....so ordering up a set for both sides and the soft line.
Then gonna take it to a shop to have it bled cuz I have been unsuccessful and its had a spongey pedal since I bought it.
Also developed a belt squeal and exhaust mani leak. This winters been hell lol
SpareParts
North Idaho
I now own the front and rear diff for my Yukon with 4.10 gears for $350. They came out of a 08 Suburban.
Guess now im committed to swapping to a true 4X4.
Now i need to find a 32 spline 261 TC. Spalding's has a few but they want $1,500 rebuilt or $800 for used.
I know another wrecking yard with one but i don't know what spline without taking it out for $100 ish.
Pretty sure i can find a used one around here on Marketplace cheaper with a little looking around.
14 bolt 9.5, G80, 6 lug.
SpareParts
North Idaho
Here's a question about swapping the front diff.
If i do not find a TC soon enough and i swap in the new diffs. Will it act drive the same if i keep the front 4x4 diff locked as the AWD front diff did?
mikez71
Are you sure the AWD front diff is locked? I'm thinking it's an open diff..
I imagine turning would chirp front tires with it locked, despite having an open center diff..
SpareParts
North Idaho
What a meant was.
If it is run in 4x4 mode will it act exactly like the AWD front diff. The diff is an open carrier.
mikez71
It will still chirp because front/rear, even if both ends are open diff.. feel bindy on tight turns..
Tight turn, mainly the rear outside wheel is moving, both fronts rolling more..
I did that in a '70s powerwagon, all open diff, with front hubs locked and 4WD engaged.. pretty sure.
SpareParts
North Idaho
Im thinking it should act exactly the same as the AWD diff does. Slight amount of binding in a tight turn on pavement.
1948Buickroadie
