battery drainage
Aj Demming
how's everyone doing.
so i tried to unlock my truck today. battery completely dead. entered via the key. turn key no lights on dash..no response. while sitting my alarm light would starting flashing temporarily. i also notice the the cabin air circulation fan (like for the heat/ac) would turn on temporarily. and then they'll both turn off for a bit. this kept happening until i was able to get a jump start. Any idea what might be happening? thanks
As @Fless suggested, start with load testing the battery at a local auto parts store with a bench battery load tester. That is the best starting point for your issue, as these trucks hate weak batteries and associated low voltages.
Aj Demming
Aj Demming
Thanks. I mostly take short trips. Battery is about 3 yrs old. But also while the truck was completely off the fan would run independently once a little power would return to the battery this is after I opened the door with the key. I’m assuming that’s what drained the battery overnight. What can cause cause something like that?
mikez71
That's GM's "Kill the battery real good, when low" feature!
3 years is the typical warranty period for new batteries...
There is an 'afterblow' feature, and others have had issues with it before.. @j91z28d1 ?
It's not supposed to keep running obviously, so most likely cause is the battery as others mentioned.
BUT you can turn it off at the dealership or with a tech2 scanner.
BUT it's supposed to prevent mildew from growing in your A/C.
homesick
The Best Me I Can Be
Navy Air Force
Does it ever sit for long periods between uses?
Mine does, sometimes 2-3 weeks. Modern vehicles have constant battery drain built in; and are much pickier about the voltage they're willing to start at.
If this is your issue, I suggest these guys. I've used them for nearly 20 years. If my bike or truck are parked here at home, they're plugged in.
joe
Foggy
KS
After a couple new batteries, and not finding any drain.....
I installed a Noco on board battery charger. It's made for installing in
the engine bay. I ran a short outdoor rated extension cord so I can plug
it in with out opening the hood. It's been wonderful...
I don't drive my Yukon everyday.. If I do, I have no issues..
Sometimes it sits for a week at a time
(I did lots of probably unnecessary stuff trying to solve drain over a year's time)
homesick
Navy Air Force
I did a similar deal. A short cable from the battery to hanging in front of the grill. A longer cable plugs in there, and runs to the actual Battery Tender. It's a weatherproof model, tied up under the top of the carport. Then an extension cord, fastened along the rain channel, to the garage.
joe
GMCChevy
Did it go dead over night or has it been sitting? Listen for the fan when the battery is fully charged or replaced and working properly. Newer vehicles do strange things when the battery is very low. But that could also be a sign there's something else wrong.
joe
Since I mostly use my truck, because my dogs demand to go everywhere with me, my 2 cars don't get used very often. Fortunately, they are both garaged, so I have AC power and battery tender chargers on both of them.
homesick
Navy Air Force
I can't post home-made pics anymore.
ATT made a change that disabled my ability to send pictures between emails and texts.
joe
Aj Demming
Aj Demming
It went overnight. Thanks I’ll try that once i change the battery.
Aj Demming
Aj Demming
joe
Sits for about a week sometimes in between use.Thanks for you help I’ll look into it
Capybarbro
