Ready to Junk it; 2007 Yukon 5.3 EVAP
juicyroot
OMG I replaced the complete EVAP on this truck and still getting p0446... I replaced the vapor canister vent valve, solenoid, (upgraded version) charcoal canister and stlll p0446.
Oh and I forgot to mention, I dropped the fuel tank and blew all the EVAP lines out and none were clogged.
If you have experienced this or have any ideas what's going on please inform.
Replaced gas cap probably 3 months ago cause information kept saying loose gas cap...
And the CEL doesn't come on for this code. CEL works because it lights up when I start the truck. I check the codes with my cheap OBD scanner, lol.
TIA my friends
mikez71
Maybe a leak in the filler tube, tank or evap plumbing?
Might be some way to check with compressed air into filler tube? not sure
West 1
Evap system issues usually show up with a smoke test. You hook the smoke machine up to your intake system and blow smoke at 3-5 psi into the system and then watch to see where the smoke is leaking out. EVAP issues can be hard to track down but a smoke test usually gives you answers in 15 minutes. Smoke machines are on Amazon for less than $100 or you can make your own.
GMT800 2005 Tahoe Z71
Navy Supporting Member
You daid you replaced the complete EVAP and then say you just blew the lines out. HUH!
I get that you are frustrated but C'mon man!
By the way, there is no code that says replace the gas cap. It will say "possible reasons for code" and then list items in the EVAP system that can set that code.
Here's the diagnostic path for that code, but when you hit the link be sure to verify that I selected the correct vehicle, or navigate to yours:
A smoke test (as @West 1 suggested) can help with diagnosis.
A purge and seal test might show a clue or two.
There is also a thread on here about what the fuel tank pressure sensor readings should be. A bidirectional scan tool that can read live data would be a useful tool.
Lastly, read the thread below and note the informative video in post #3 (GoTech Wells CounterPoint linked below):
J
juicyroot
I guess you didn't comprehend what I said HUH
I BLEW ALL THE LNES OUT ON THE TANK AND NONE WERE CLOGGED
setha8
CEL is not on. Only in the ECU I'm guessing. I erased all codes after new evap installment
Then you are good! You are probably seeing the "archive" code, which means it's not an active code. Mine is the same way after I cleared the lines. I can see that the code once active, but is no longer active. If the code comes back then you will need to do a smoke test like someone mentioned above.
I actually do have a small leak still, and my CEL does come back on at about 1/3 fuel level when it runs the test. I finally took the time to smoke test it to find exactly where the leak is.
J
juicyroot
Thank you
I was thinking fuel tank pressure switch but then the fuel pump was replaced like 9 months ago
Easy enough to read the fuel tank pressure sensor voltage with a decent scanner, and compare it to what it should be, say, at atmosphere, and what it does when the tank is pressurized. Mike does a good job of explaining that in the video. Eric O (YouTube - South Main Auto) has also done a video or two where he does the test, and at least one was the tank pressure sensor.
setha8
I took his comment to mean, you didn't do all that much to be frustrated to the point of wanting to junk your vehicle.?
Looks like some good videos, keep us posted.
No kidding! I spend two days clearing the line between purge valve and the front of the fuel tank. Soaked it in B12, blew back and forth, back and forth, once clear, then changed canister, vent valve, purge valve, dropped the tank and blew every line out on that end of the system. And even then I wasn't at the "junk the car" stage, lol.
J
juicyroot
Maybe so but I've had this vehicle little over a year and I've had a ton of issues with it. It's been a money pit!
AllyNJ
