11 Yukon XL Denali Electrical Issue P0621 SOLVED
S
SteelBaller3
Voltage not necessarily too high, the charging system allows that when it thinks it's needed.
If your modules show low voltage due to a bad ground, it would be cranking up the alternator voltage.
Since you have a scanner, try and look for 'control module voltage' or something like that.
I will go back out there and do that soon my wife had to leave for a moment so watching my kids. But I also noticed when I tried to graph the battery it’s just blank with no readings. When I go to component testing to try to control certain components it says module not supported or something like that.
S
SteelBaller3
Graph like you did with pedal position might show better if its fluctuating, with engine running.
I will. Wife had to run errand and I’m watching the kids. I also noticed when I tried to graph the battery it didn’t show anything. Just blank. When I try component testing it says module not supported
S
SteelBaller3
Sorry didn’t mean to double send that. But I will check that too as soon as I have more than 5 minutes to troubleshoot. L terminal circuit is what plugs into alternator from ecm correct?
S
SteelBaller3
The big fluctuation is when I started it
mikez71
normal, try unplugging alt connector
My pedal position logs like you would expect, flat at idle, D and E signals mimic each other but at different scales. Pedal connects straight to ECM, D signal goes to 84% at WOT, E signal to 41% (4.2V and 2.06V)
18.8% and 9.4% at idle. (.95V and .45V) respectively..
and maybe you should tell us the other codes
Foggy
KS
My guess is battery isn't good.. Need to LOAD TEST It !!
Ohmmeter voltage is barely useful when checking condition of a battery.
IF the battery is weak, That would explain why the alternator is charging
at 15+ volts - to recharge after a start with a weak battery
mikez71
Would a bad battery still cause these issues after starting the engine, and the alternator outputs steady voltage and computer modules all have stable voltage?
I was thinking the control circuit on alternator initially also, but again he seems to have steady voltage, which can still be controlled to ouput 15V - 15.5V.
Looking at his pedal datalog makes me think pedal is toast and causing the rough running. (or bad ECM, because pedal connects straight to ECM, and D and E both ground to the same ECM pin F)
Voltage issues maybe a separate issue..
Those other codes might help, but he wants to keep them a secret for some reason!
Well, if the somewhat simple diagnostic path tests were done for the listed code, we'd have better info. There's a reason that code is showing.
S
SteelBaller3
okay sorry been super busy. Didn’t have time to take alternator off and test at autozone but did battery today and they said it’s perfect. Doing alternator test tomorrow. I tried running the simple test with the wires. I had 4.5 at alternator plug but couldn’t get the ecm connection off. Ended up snapping the red pull out. My personal opinion is it’s the ecm. The other codes I can’t post a video and that’s all I have of them but I’ll screenshot them.
S
SteelBaller3
Also idk what these codes even are because they are not in history and current. They are in additional. Whatever that means
jkhuntzinger
