Vladimir2306
- Joined
- May 18, 2023
- Posts
- 1,064
- Reaction score
- 1,250
I'm desperately trying to find the logic in towing a heavy trailer at 94mph... oh well.
For fast cargo transportation across vast Russia))Trailer push truck in Russia
I was thinking of I20 and I40 in west Texas actually. lol. The Bro Dozers are insane.Things are different over there.
What kind of tires do you have? In principle, cheap trailer tires have a speed index of 140 kmh, or almost 90 mph. And if you put sports, high-speed tires, then people with trailers and jet skis travel 200 kmh, which is 125 mph or more))Most trailer tires can't take 55 miles an hour, let alone 95. That would be a rolling bomb as far as I would be concerned.....
Gotta ask, what kind of mpg's do you get at that speed, 6-7 mpg?The logic is simple...if there are roads and traffic conditions that allow you to do this, then why not drive like this?) Fuel consumption is only high, you often have to stop at a gas station, but still, you reach your destination quickly.
In the US, common trailer tires are not rated for 90mph+ is my understanding. This is from -https://tirecrunch.com/trailer-tires-speed-rating/What kind of tires do you have? In principle, cheap trailer tires have a speed index of 140 kmh, or almost 90 mph. And if you put sports, high-speed tires, then people with trailers and jet skis travel 200 kmh, which is 125 mph or more))
@Antonm -- Please, already asked once (#23) to start your own debate thread on Oil Merits elsewhere...this thread is supposed to be for people to understand the experience of having a 6.2 fail and subsequent repair.Perhaps he was trying to "prove" that the 0W20 oil he loves so much can handle the abuse of such a situation (because you know GM had that use case in mind when they spec'd 0W20).
Of course no oil can magically fix manufacturing defects or remove machining swarf left in the engine, but there is a reason high HP / heavy use vehicles spec an oil that's a little thicker at operating temp.
During such continued high HP usage, I'd bet the oil was screaming hot (and thin as a result of the temperature). The addition of another oil cooler would help (the L87 has an oil cooler , but its pretty small) if one was so inclined to continue to tow at high speeds (again , not a new concept, every diesel pickup engine out there has a huge oil cooler for a reason).
Yes, intake and water pump are not included and get moved over.Walleye, do you know for sure that the replacement engine does not include a new throttle body?
And why torment the dealer? there is a review bulletin, everything is written there that is changing. in particular, the oil cooler and the oil line are additionally changed.Walleye, do you know for sure that the replacement engine does not include a new throttle body?
The process of replacing the engine is 1 day of operation, as well as its start-up and calibration of all systems. so two days and everything should be ready. It took me 9 days, but it involved disassembling the old one, repairing it, then buying a new engine, disassembling it, and reassembling it.Dealer called. All parts needed have arrived.
Said they hope to start the replacement today.
They promised me next week early, but they are not working on Chirstmas Eve or Christmas Day.The process of replacing the engine is 1 day of operation, as well as its start-up and calibration of all systems. so two days and everything should be ready. It took me 9 days, but it involved disassembling the old one, repairing it, then buying a new engine, disassembling it, and reassembling it.
I told you, there is 1 day of work)))Service advisor just called. Yukon is ready for pickup, I won’t be able to get until Monday due to the holidays…but they said it’s ready to go!
