Diff
Dustyhd05
Can I run just 4.56 in the rear diff and leave it stock in the front as long as I don’t engage 4wd? With drive shaft still attached? Replaced the rear diff and not front yet and my Speedo is way off.
GMT800 2005 Tahoe Z71
Navy Supporting Member
The tires can have a lot to do with it too. There is a way to work it out on paper but yes, you will need some tune work. Contact a vendor here, Black Bear Performance, and see what they say.
Sounds like you've done it already. On the generation after yours, the computer system would have a fit with one axle turning a different speed than the other. Doing so on those turns off the ABS and other safety features.
albac
