Misfire after head gasket replacement
Hmj7819
Hello! I have a 2007 chevy tahoe 5.3L Z71. I recently replaced the head gasket, coil packs,spark plugs and wires. I upgraded to a cold air intake also. Now when I start it it stuggles to turn over and has a significant misfire on cylinder 1 and 8. I switched out the coil packs, plugs and wires on both cylinders and it made no difference. I dont remember the codes it was throwing at the moment. I also replaced injectors and upgrade to a 4 port from a 2 port injector. Cylinder 1 and 8 are loading up with fuel. Please help.
rdezs
Rule number one, don't replace multiple things at the same time. I would start by reinstalling your OEM air tube and filter. Quite possible it's simply running too lean from the cold air intake....
rdezs
Just realized you mentioned it struggles to turn over. Ditto on checking the battery connections. Also the ground to the cylinder head.
B-train
Have you lost any coolant? I also second the battery cable connections and ground. You could try a voltage drop test on the cables and see if you have high resistance internally.
Were any other sensors replaced when you did this work?
Hmj7819
Hmj7819
This started as a top end rebuild due to a blown head gasket
That would cause 2 cylinders not to fire?
Hmj7819
Hmj7819
No I’m not loosing any coolant now that I’ve replaced the head gasket. I did replace the negative battery cable back to an OEM cable. I scraped, sanded, and cleaned the ground connection..
Hmj7819
Hmj7819
Fuel is loading up in the 2 cylinders also.
Hmj7819
Hmj7819
No sensors replaced
mikez71
No way the ignition coil wires could swap right?
I figure the're on opposite sides and ends.. but they all go to ECM..
The wire is purple for coil 1, and purple/white for coil 8. (ECM ground trigger)
Maybe check all the wires at coil connector, grounds and power.
BTW did your old starter feel like a case with loose parts inside?
rdezs
I would reinstall your OEM air intake and filter simply to rule it out.
When you have the heads off, did you have a machine shop skim them and make sure they're flat? I would think that most likely it's going to be one of the harness plugs. (Or a broken wire in the harness from disturbing it. Our harnesses are starting to show their age)
^^This. A lot of new (questionable) parts have been shotgunned.
What was wrong with the coil packs?
mikez71
I just noticed you said "upgraded injectors.. 2 port -> 4 port"
Maybe you're talking about the steam ports in head?
Tuners want very detailed info on the injectors.
They won't run anything without complete injector data..
And it needs to be input into the tune..
Is this a known good injector upgrade?
You have tried swapping plugs/coils/wires around, but not the injectors.
j91z28d1
curious of why it blew a head gasket. ls engine isn't really known for doing that.
did it maybe over heat badly before?
West 1
Pull the plugs that are loading up, I suspect they will be very wet. A leaking injector causes hydro lock in the cylinder. Don’t mess with it or you will bend a connecting rod or break a piston. With two plugs removed spin the starter, I bet it spins normally.
If the injector is over fueling you will need to find out if it is computer related or a bad injector.
1948Buickroadie
