Hi,
I'm having trouble with the fans after installing the harness...I've gone over and over my install and can't seem to find my problem.
So what happens is the pass side fan comes on when the key is turn to run position..and thats it. Then the truck overheats after running a few minutes.
The driver side fan never comes on, and I suspect the pass side fan is only on a low setting. The pass side fan remains running for 5-8 seconds after I stop the truck.
I triple checked that blue pin 42 was in the correct blue plug,.
I tap'd the "AC tap wire" into the lime green wire on the loom running verticle alongside the alt bracket. The "AC tap wire" color does not match the dark green wire in the compressor plug...is that an issue?
Any ideas?
Any ideas?
I only have one of mine working and my mine won't overheat using one. It was 98 here today. ???
