Are the Dual Piston Rear Calipers noticeably better?
5StarCustmSolutns
5StarCustmSolutns
Almost Heaven, WV
I have found using the tow/haul feature works exceptionally well for high speed down hill curves, takes a lot of the load off of the brakes.
your 2011 should have the grade-braking feature with the tow button on.
Prob shouldve clarified that in those scenarios I was trying to get to a checkpount location and get set up before the first vehicle in class arrived. I was accelerating to whatever I could get up to in between those sharp turns. Basically going from one pedal to the other until the brakes got enough heat in them that they began to fade.....
I'd say about 85-90% of the time I drive in Tow/Haul and M5, and I agree under normal conditions Tow/Haul does exactly what it supposed to do! A+ feature and function
strutaeng
Dallas, Texas
@5StarCustmSolutns not sure if you were asking me?
I have no idea what rear wheel diameter you need for the Corvette rear brake upgrade.
I think this may be the kit though. You can probably call those guys and ask them. It says it works with 1999-2018, 6 lug with rear disc. So basically GMT800/900 and K2XX.
5StarCustmSolutns
5StarCustmSolutns
Almost Heaven, WV
I think someone did that before you got it. If you're the original owner, well then, I learned something new today!
Yeah, I hope this post doesn't damage my street cred on here too severely lol, but I totally mis-thought that.. I was thinking somewhere along the lines of the 4 piston upgrade for the front and how the ratio for the number of pistons rear to front is .5/1 and No.... Mine came with and has single pistons on the rear. Thank you sir for pointing out my err ;)
5StarCustmSolutns
5StarCustmSolutns
Almost Heaven, WV
Well that’s not what I expected. 20” min for the front brakes. Here’s the rims the Popo use for those.
I wonder if the four pot brembo will fit under the rear 18”?
4piston front brake kit fits under 18" wheels.
6piston front brake kit needs 20" wheels.
So I finally did someting with this subject...
And in my final educational session I came across this thread in my search results lol...
Upon re-reading it I realized there was some good info in here that I had not absorbed...
Thank you to all who contributed...
My main unsolved mystery was:
Will the 4 pistons fit inside 17" wheels?
...and the answer is Yes (but only if your math, math's out right)
Recently came across a pair of 4 piston caliper + pads + rotors + dust shields off a 2026 Escalade for $225. Was told they were driven during test drives and from dealership to afermarket shop, which was pretty obvi in photos. I double checked for fitment? Consensus was they fit with an approx 0.125" hardened spacer between caliper and bracket (moving caliper 0.125" outward).
They were a couple hours away but in a town where a longtime friend lives, and he comes here to work 1-3x every week. Called him up and he was coming next day. Had them in my hands in less than 24hrs lol.
Didn't attempt to install them until this morning...
I'll post pics immediately after posting this... Theyre on my phone and I dont have cord to move them over here w/me...
As you'll see in pics: They fit! Barely! ...and I mean BARELY!
0.105" clearance from back spokes lol... I'm running a 17 x 9 +18 with a very mild curve or dish shape in the spokes. ZERO chance they fit w/o that subtle curvature to the spokes. 0.105" is 1/4th of 1mm
Already ordered some hubcentric 3/8" spacers as that is too close for comfort imho...
**EDIT: Canceled spacer order....for now lol...
Im gone try to explain this as concisely as possible (sometimes hard for me)...
>>(Technical) Functional Fitment for the newer GM 4 piston brake upgrade onto a GMT900 is a combination of three distances and one wheel design feature....and it's not very easy to explain.....and even harder to comprehend if you dont have some decent knowledge/experience with these systems...
Those are: wheel offset, caliper spacer size, wheel width, and spoke shape. Rotor hat height is another distance that plays a role, but its role is only in the measurng of your current setup, just to see if your wheels are compatible.....but this post is long enough already so:
In short: the most common point of contact is casued by the 4" x 0.5" raised rectangular bump out on the outside face of the calipers. It makes contact with the backside of the wheel spokes.
If you're considering this brake upgrade? Before you do anything, put a tape measure through your spokes onto the face of the rotor and see if you have 2.5" or more available from the face of your rotor to the back of your spokes? Make sure to take note if you have a different measurement closer to center than out towards the tire? because that plays a role too...
That's a START...
Hope this helps someone some day...
5StarCustmSolutns
5StarCustmSolutns
Almost Heaven, WV
Driver side was 0.16"... Which looks like a canyon after ripping business cards (before getting out gauge) in the 0.105 gap... (and no make fun of my brake dust covered wheel or failing rust protection on frame, I'm already self conscious enough about them lol)
Pass
Drive
Comparison of the OE sized PowerStop rotors (once turned) vs 2026 rotors
Approx:
0.08" thicker (2.03mm)
6lbs heavier
16mm larger diameter
Hard to show they're centered on rotor w/pics
Was concerned about fluid loss. It was extremely minimal and mitigated on driver side with this little cap...
Very simple install...
Notes: When pressing new line up through bracket to attach to hard line you must clock it correctly. Rotate until little flanges align with grooves in bracket. You'll feel/see it seat, upwards, into the correct position. Must do this so retainer clip can do its job...
Used 12mm, 10.9 hardness rated washers by Everbilt as the spacers. They were approx .011". Interweb said spacer should be 0.125" but mine was immeasurably close to dead center w/0.11".
Bought at Home Depot out of the specialty drawer in hardware isle. Pack of 5 was _____(not much? less than $5? maybe? honestly didnt look at receipt)
I had to bore/rheem out center hole about a 1/16th for the 2026 bolts, which I forgot to mention came with the other parts...
Even w/ drill press this took longer than the install per side! (10.9's are harder steel)
***AVOID this by using 14mm 10.9's or 5/8" grade 8
Will update performance after I get this wireless switch panel installed..
I have to be in SE Ohio in about 6hrs to run sweep for the 24hrs of Appalachia: Buckeye Blitz 2 Off-Road Endurance Challenge we're putting on this weekend...
***Edit: the dude I got these parts from had two more complete front sets... Let me know if interested? Wouldnt arrive with the speed of an old school SummitRacing delivery lol, but I could get them to you... I'm honestly not sure how much $$ I even saved? Iirc, I got the cal, rot, pad, dust shields(which I did not install yet), & bolts for around the same cost jeffazon sells the cals only for?
[Its about more than saving a few Fed Res Debt Notes for me though, I'm trying to grow, to learn more about systems, be a better problem solver, expand my network, and be more resourceful....more valuable. When we re--purpose re-use re-store re-juvenate (and about 10 more "re-" words), it reduces demand, which lowers costs for everything, for everyone ]
Like I say in earlier post: I'm not recommending you do this, most esp if you're not mechanically inclined. This is just what I did for the off-road race capable truck I'm gradually turning my GMT900 into
Bronson357
So my 02 burb,2012 burb,07 tahoe all use dual piston rear calipers,00 1500 silverado uses single piston calipers. Seems weird since the truck would normally be loaded more often. Also all of these vehicles tend to eat rear brakes 2x as often as the front?
varminpoolteam
