thefrey
- Joined
- Feb 3, 2025
- Posts
- 419
- Reaction score
- 469
Yes that’s what I’m using. Huh. Interesting considering 5w30 is what’s recommendedYour oil is too thin. Valvoline Restore and Protect, right?
Restore & Protect Premium Full Synthetic SAE 5W-30 Motor Oil - Valvoline™ Global
The first motor oil that removes up to 100% of deposits and prevents future deposits, it also delivers 79% stronger anti-wear protection vs. industry standards.www.valvolineglobal.com
See that KV100? That oil is 10.8. Too thin, you want well over 11. See the Viscosity Index of 161, too low. These LS engines like higher, around 170.
Quaker State Full Synthetic works as well as ACDelco's oil and even Red Line's for reducing lifter rattle.
Those "thin" oils leave a lot of metals in the engine oil at the end of their run. I documented this with regular Mobil 1 and ACDelco and Quaker State in 2 different LS engines.
Is the KV100 dependent upon oil spec or is it the same across all viscosities?
I switched to Valvoline restore and protect because that’s what a ton of people have recommended in this forum since it seems to do a really good job at cleaning.
So, is a potential fix (maybe not fix but higher KV100) going up in oil viscosity? Or is it changing brands totally?
Is the lifter rattle potentially a byproduct of thinner oil which would cause the lifter to not pump up fully or is there another reason?
