MrDietz
- Joined
- Aug 5, 2025
- Posts
- 29
- Reaction score
- 36
Hello everyone . I am new to the forum so just wanted to say hi and ask for help. please forgive me if i forget something or if i am all over the place. thanks in advance.
so i bought a 2007 ppv that had been sitting for two years. drained the fuel and and put a new battery in it and fired right up. drove it about 40 miles to get it home with no issues everything working. changed the fluids and started driving it to work. after about two weeks i was on the freeway and i lost all gauges it just went dark so i pulled to the side of the road .(truck was still running) shut the key off and checked everything out. at this point i was assuming it could have been the alternator or the battery and needed to get to work, so I got it towed home. alternator tested good from two different places and battery tested good(its brand new) and its charged. (just trying to give context sorry for the long story) the interior lights would always come on once i hooked up the battery but they were very dim. so i started basic check power and ground . the ground on the passenger side cylinder head was loose. so i tightened that up and fixed the lights from staying on . while the ground was loose before i found that it was loose.the blinkers and headlights worked but once i tighted that ground the headlights and blinkers stopped working. I am wondered if that ground being loose fried the fuse box or the bcm. none of the interior lights are working, locks don't work. can not open rear liftgate , the radio works. ac blower motor kicks on. all the warning lights pop up on dash, windows roll down and horn works. but none of the gauges/needles move at all .fuel, voltage ext.... the line under the prndl is not there ,the mileage and trip do show. all fuses are good under hood and in cab,including the main fuse that powers fuse box . i can jump the starter and it will crank just wont run, just another thing to eliminate. i did notice the power/tran and run/crank relays getting a little warm just sitting there with battery hooked up no key on. i did replace the relays with new ones and still no crank. i am going to try to ground those relays with a jumper since they do have power to them. all the stuff not working does not have power at the fuse box under hood. i have been limited on time so this weekend i am going to be able to dive in . i got my fluke and light tester out of storage and i have access to pro demand so i will be printing out the schematics for this weekend. I just wanted to post on here to get the gears turning in case i dead head while going thru it this weekend. so i can have somewhere to turn instead of scratching my head. thank you to all for any help or insight. look forward to making some new friends and talking about what mods im going to do to this hog once its running again. first mod was a lace steering wheel cover to give it that old truck feel. lol thanks again.
. they said if i have not recivied it by 8/19 request a refund and it was there last bcm thru that seller. fml so i will order one thru another seller and hope for the best.
