Front control arm suggestions please
JMH1980
I have a 2016 Yukon XL Denali.
It has about 100,000 miles currently and I'm just doing pre search for quality replacement parts for when the time comes.
Control arms upper and lowers
Stabilizer bar links and bushings
Tie rod end links
And anything else that can be recommended
Thanks !
Moog CK Series are often the same as ACDelco Gold/Professional and neither lasts 50K miles, generally speaking. Moog RK Series is their lowest quality offering.
When I rebuilt my suspension, it was GM OE parts all the way save for the rear springs. It's been 4 years and 52K miles since overhaul and she rides great still.
GM OEM is the way to go, and that is what I did, when the time to replace came. Control arms come with the ball joints already installed. Check GMPartsDirect.com or RockAuto.com for the best OEM prices, way below the Dealer's prices.
You will need to confirm correct part numbers with your VIN, but here is what I see on GMPartsDirect.com:
Front Driver Side Upper Control Arm
25812725
GM
Notes:
Includes Bushings And Ball Joint.
Description: This GM Genuine Part is designed, engineered, and tested to rigorous standards and is backed by General Motors
MSRP $308.14
$197.00
Front Passenger Side Upper Control Arm
25812726
GM
Notes:
MSRP $308.14
$197.00
84114506 - Suspension: Lower Control Arm for Cadillac: Escalade, Escalade ESV | Chevrolet: Silverado 1500, Silverado 1500 LD, Suburban, Tahoe | GMC: Sierra 1500, Sierra 1500 Limited, Yukon, Yukon XL Image
Lower Control Arm (Stamped Steel)
84114506
GM
Notes:
Includes Lower Ball Joint And Bushings.
MSRP $378.31
$238.27
84114505 - Suspension: Lower Control Arm for Cadillac: Escalade, Escalade ESV | Chevrolet: Silverado 1500, Silverado 1500 LD, Suburban, Tahoe | GMC: Sierra 1500, Sierra 1500 Limited, Yukon, Yukon XL Image
84114505
GM
Notes:
MSRP $378.31
$238.27
BigPac
was looking at these, RC county ones... look HD
TejasPitt
