How to install my radio.
Dan2002
got a cheap double din from amazon,
had it on other vehicle.
i want to intall it in my 03 escalade but doesnt seem to work
i bought the harness and it doesnt turn on, there is no power to the ignition activated wire. the constant 12v is good.
i have cheked all fuses and nothing. so what i did is got a ignition 12v from somewhere else. and it worked. but now there is no audio at all.
it has the BOSE system
D
Dan2002
if you have RPO code Y91, it is the Bose Luxury system which is wired differently thus needing a different harness than the regular Bose Premium found in tahoe/yukon/sub.
yes it has Y91
Tonyv__
Bucks county PA
IF you went with the cheapy harness without all the modules and stuff. You just need to get 12v from the fuse box inside the cab on a circuit that is controlled via the key like HVAC for example
Use a fuse tap like this
Then after you get the radio on, you’ll likely need to send remote signal to the factory amp. I forget what color wire that is
Durobans
