02 tahoe, aftermarket double din installed, Easiest way to bypass factory amp?
Corydolo
02 tahoe, aftermarket double din installed, it came on but no sound. Original oem only had 1 working speaker. Easiest way to bypass factory amp? I bought all harnesses, is is it as simple as jumping a new 12v wire to factory amp? Or just bypass and run off of aftermarket 60wx4 along with sub and amp package?
Tylerstc
You don’t have to bypass factory amp if it still works it sounds good if you just turn it on but run your remote to the pink wire behind the factory plug that should turn it on but you will have to connect it then turn truck on and see if it engaged
mudrunnerz
