solli5pack
- Joined
- Jun 17, 2023
- Posts
- 484
- Reaction score
- 741
Bled them again..better but still mushy pedal
I have before but i like making the family miserable and tired for 1/2 hr every once and while…. Its fun!Y'all ever gravity bleed? That's what I do and seems like the easiest way to bleed brakes ??
That's all I ever do on all our vehicles,Y'all ever gravity bleed? That's what I do and seems like the easiest way to bleed brakes ??
When I did what you did I was able to have an assistant press the brake pedal while I cracked the brake line fittings at the MC. That worked for me to get the last little bubble out of the MC. Good luck.Bled them again..better but still mushy pedal
I wish I would've know about this one before I bought the vacuum bleeder from Harbour FrieghtEveryone needs this: https://www.amazon.com/Motive-Products-System-Bleeder-Trucks/dp/B000TK9FE8/130-9146754-1576554?th=1
One-man jobs are a breeze, and you don't need to fill this with the fluid, just top off the vehicle's reservoir, and add fluid for each caliper. Plus, you can buy adapters for every make/model out there. I pump mine up to 15psi, and crack the bleeder until the fluid runs clear for a little bit. Brake flushes take 10 minutes (after you spend 20 mins jacking up your rig, and taking off all the wheels).
Same. I got mine at AdvaceAuto, and it was junk from day-1.I wish I would've know about this one before I bought the vacuum bleeder from Harbour Frieght
I have that one from Amazon it works great.I wish I would've know about this one before I bought the vacuum bleeder from Harbour Frieght
Seems like I might have been the victim of a overnight phantom brake bleed. Pedal feels much better this morning then when I was driving it last night. All I did was park it backed into the driveway so the mc was slanted down. Maybe it burped in the middle of the night? Im not complaining...I've seen a few videos describing this phenomenon...
