6.2 Engine recall SAE 40 OIL
Status
Not open for further replies.
NELLY1947
Hi all
As we are all aware the recall on the 6.2 engine is still up in the air as to what to do. My dealer is saying they are still in the dark over the solution. But one of the is possibly to in the future using SAE 40 instead of the standard SAE 20. I'm thinking of changing right away on my own . Any comments? Pro and Con.
Thanks
WalleyeMikeIII
Sunny and Snowy Minnesota
Suggest reading this thread:
KMeloney
Hi all
Thanks
How have you NOT seen the recall thread?! LOL Lots of OPINIONS (with some facts mixed in) on the whole oil issue aspect.
In a nutshell:
PROS: It may just prolong the life of your faulty engine
CONS: GM doesn't recommend it for engines that are within spec, more expensive, slightly worse MPG, maybe GM determines you haven't been using the recommended oil and gives you a hard time [over future engine repairs/replacement]...
Marky Dissod
PROS: It may just prolong the life of your faulty engine ...
past 10 years / 150,000 miles, GM no longer cares - even though it ought to last 25 years / 250,000 miles.
If your L87 does not make it to at least 200,000 miles, GM wins, you lose.
CONS: GM doesn't recommend 0W40 for engines that are 'within spec'; more expensive, slightly worse MpG,
maybe GM determines you haven't been using the recommended oil and gives you a hard time [over future engine repairs/replacement] ...
Note that GM failed to suggest / recommend 5W30, as prescribed for the 6.6L L8T.
A set of facts being ignored are as follows:
1. Physical spec design & manufacture similarities between the LT1 (0W40) & L87 (0W20)
vastly outnumber any differences that would be affected in any way by 0W40 vs 0W20
2. Biggest reason for GM to spec 0W20 vs 0W40 is CAFE MpG test scores
Nelly, and anyone else wondering:
if you want to try to keep your L87, 0W30 / 5W30 / 0W40 / 5W40.
Used motor oil analyses will better inform you than reading emotional conjectures that resemble Soroborou, the snake that shoves its head up its own arse.
if you want to try to have GM replace your L87 before the warranty expires, 0W20.
Unfortunately I've not been able to think of anything else that can be done to make the L87 fail prematurely. (Maybe drive it with more gusto?)
Wonder why no one else has either.
Let's keep this in one thread:
Status
justinakay79
