2013 Rear Windshield Pump No Power
Colorado Hoe
Just purchased a 2013. Everything works except the rear windshield washer motor. Checked fuse, swapped with known good fuse, replaced steering column stalk switch with a new one, removed rear washer pump and hooked up to battery and the motor works.
I've looked for, but haven't found a wiring schematic for the washer pump circuit to see if there are any related relays. Does anyone have any experience troubleshooting no power to the rear washer pump?
14Tahoe
Before you check power, have you checked the thin black washer fluid tube in the engine bay? It runs downs the drivers side to the back window and can frequently get disconnected.
mikez71
Looks like the relay is one of those mounted inside the main fusebox...
-IF- that's the culprit, I've only seen people replace the main fusebox so far..
^^^^^x2^^^^^ Look for washer fluid dripping down onto the ground. This may not be the cause of your issue, but it fairly common.
I am assuming that you tested the connector to the rear washer motor to see if it has 12 volts, when someone pushes the rear washer button.
C
Colorado Hoe
Yes, I've checked the fluid line. Thanks.
And do you get 12 volts to the connector to the rear washer, when someone pushes the rear washer button?
No power to the rear washer pump when the switch is pushed. Switch has been replaced with a new switch.
OK. Next try wiggling the wire that goes from the truck body to the rear door. Since that wire bundle is moved every time that the rear door is open, it get a lot of movement, which sometimes results in wire breakage.
EDIT: the above is wrong. Please ignore.
OK. Nest try wiggling the wire that goes from the truck body to the rear door. Since that wire bundle is moved every time that the rear door is open, it get a lot of movement, which sometimes results in wire breakage.
The pump is not back there, it's in front on the washer fluid tank
I would check at the fuse box to see if the fuse is good and to see if there is continuity between the switch and fuse and from fuse to pump.
should be a normally open circuit and constant ground.
Conedaddy
