- Joined
- Sep 19, 2018
- Posts
- 4,858
- Reaction score
- 13,713
I haven't driven it since then, but I checked all 4 tires today.Excellent! Time will tell.
The problem child matched the other three.
joe
Thanks, man. I hadn't thought that far ahead.It fixes it long enuf to forget about it until it’s time for new tires. You may want to use a paint stick on inside of leaky rim’s tire and write “buff & seal”.
Two years from now your tire installer will hopefully mention it to you so sealant can be applied again to avoid the $75 reseal process.
My oem 22s on my 19 Denali were leaking. All of them. I pulled the tires off, wire wheeled the inside lip, knocked all the loose corrosion off, then put bead sealer on the wheel only. Cleaned the tire bead and remounted them. So far so good.I have a 2007 Escalade with the OEM 22" chrome wheels. The front left tire keeps leaking down. So far, two different shops have failed to fix it.
The second shop blamed the factory wheels, and put a sealant on the bead. He said it might not work, and it hasn't.
So, any ideas for a solution?
joe
As much as these "accessory" wheels cost, it's pretty ****** they peel/"rust" like that.
Its been a month.How long since?
joe
