That’s how I’m trying to look at it. Planned on buying a junk core and building it myself as a backup but the truck decided to create the junk core for meWelp at least when you're done it's one less thing to worry about![]()
No pics it didn't happen. LolFinally got around to installing the Glenn's Auto Performance trans cooler kit. Definitely a big improvement over stock. Lines fit perfect. Cooler and brackets were all exactly the fitment I was hoping for.
This is the only photo I took. I actually removed the push bar. It's time to change the look of my Tahoe. I'm looking for projector retrofit headlights and a good front turn signal housing.W
Grab some Sierra Denali or Yukon Denali projector headlights.This is the only photo I took. I actually removed the push bar. It's time to change the look of my Tahoe. I'm looking for projector retrofit headlights and a good front turn signal housing.
Those are shaped differently than the Tahoe headlights aren't they? Do they fit the fenders and hood? I know the grill is shaped different for sure.Grab some Sierra Denali or Yukon Denali projector headlights.
I believe they do, but my wife has been difficult, so I haven't been able to put the ones on her Suburban that I have. But I believe a "bubble eye is a bubble eye" -- nothing else really matters.Those are shaped differently than the Tahoe headlights aren't they? Do they fit the fenders and hood? I know the grill is shaped different for sure.
I have a 05 tahoe and Denali and I don't see how those headlights would fit each other.I believe they do, but my wife has been difficult, so I haven't been able to put the ones on her Suburban that I have. But I believe a "bubble eye is a bubble eye" -- nothing else really matters.If you are in the DFW area, I'd be happy to let you test fit mine.
| RR window motor and regulator tyc brand | Mar2020 | 186k |
Sway bar end link on driverside. Daughter sent me a video message.... dad it makes a bang when I turn. And yes it did.
It would come out of the pocket on left turns and slide and pop back in on right turns.
Dang! Barely even almost broken-in....
She is pretty good at that. Not always, but if it is noticeable she will tell me.Good for her to tell you!
