thefrey
- Joined
- Feb 3, 2025
- Posts
- 419
- Reaction score
- 469
Bit of background - 201k 2013 Denali. I just dropped the pan to swap the o-ring and tried to look at the timing chain, and well, she is loosey goosey:
They are both the same side in the clip FYI just the camera is flipped
How urgent is this? Should I replace this ASAP or can I run it for awhile? Is it worth it to do on an engine that has 201k?
Here's an idling clip (unknown if there's chain slap)
I will probably drive the car for another 50k miles before I start start considering another car. Also I'd do a new oil pump while I'm in there.
Also, has anyone done this without dropping the pan? I'm a bit discouraged, since I just dropped the pan and put everything back together. I was under the impression that you didn't have to drop the pan and could just go through the front cover, so that's why I didn't do a timing chain while I was doing the o-ring, but I may be wrong. I've also never done a timing chain before - dropping the oil pan with the AWD was hands down the biggest job I've done so doing a timing chain will be a challenge. I'm not scared per se, but there's obviously no room for error with this one.
Appreciate any help or feedback. Ya'll are great
