Valvoline Restore & Protect experiment
rdezs
Here's the VLOM plate.... You can see the clean areas where apparently it was leaking.
rdezs
Just a follow-up on the neighbors vehicle we completed the AFM delete on. He has put 250 miles on it, and is highway MPGs have increased by 1.8 MPG. He's now at 20.1 MPG. I know he's driving it like a sane person for the first thousand miles, but commented he's never seen anywhere near 20 miles per gallon before. I'm chalking it up to using the OEM L92 camshaft. (Which is interesting, because that would suggest GM lost fuel mileage by designing the AFM system.) I can't imagine the Valvoline had that effect on it, unless it freed up some stuck piston rings and restored compression? Quite possible I suppose.
Marky Dissod
... can't imagine Valvoline R&P had that effect on it, unless it freed up some stuck piston rings and restored compression? Quite possible I suppose.
Years ago, I INCREASED the V4 mode duty cycle on a 2012 Yukon XL I was leasing for NYC livery driving.
Point was to be in V4 mode as much as possible driving in Manhattan.
It was a mistake.
MpG gains were barely detectable between the first and second years.
I left it alone to try to encourage myself to drive in featherfooted style so as not to agitate my riders.
In winter of 2017-28, oil consumption went up drastically. Think the piston rings were 'coked up'.
I wonder if Valvoline Restore & Protect would've been of any help?
Truth is I should've raised the V4 mode enable temp to 235F.
rdezs
I would say in the AFM deletes I have done, people on average report about a one mile per gallon increase just by disabling AFM in the ECM. Then after the AFM is physically deleted, usually there's another one half to one mile per gallon increase. Not entirely sure why. Almost all of them, the heads have been flat, and the shop I use skimmed less than a thousandth to clean and get the RA correct. In this latest case, the Valvoline may in fact have freed up a couple rings. One thing is for certain, in all cases they idle a lot better after replacing all the lifters and the cam.
T
the blur
Cyber Space
I bet they would idle better if you didn't touch the AFM. You are basically replacing the top half of the motor, of course it's going to idle better, and run better with a fresh cam & lifters.
rdezs
It's not just the new cam and lifters improving the idle. It's getting rid of the complicated AFM system that leaks a lot of oil internally, which clearly affects how well those AFM lifters are operating in the V8 mode even. Results in a very unbalanced system, sometimes well under 100,000 miles. I think the system probably works well for the first 20 or 30,000 miles, and at some point there's a gradual process where it's efficiency drops and affects fuel mileage overall. Unfortunately, sometimes that process isn't gradual and one of those AFM lifters destroys the engine. A very risky technology in an expensive engine you would prefer to last well over 100,000 miles. The non AFM L92 is a perfect example of the same 6.2 that typically lasts much much longer and doesn't have a history of imploding. The AFM in the most basic description is a politically based technology to assist GM in meeting its CAFE requirements as the car is driven off the lot. It's benefits and fuel mileage don't last long enough to make it worthwhile, and it soon becomes a liability to the engine having the opposite effect of its intended purpose.
Marky Dissod
Pretty much this - then GM doubled down by adding V7 V6 V5 V4 V3 V2 and I2 modes to their V8s ...
(My suspicion is that their intent was to make their engines more likely to fail at around 200,000 miles.)
Between 30,000 & 60,000 miles, Engine Half@$$' MpG benefits over V8 mode evaporate.
Cylinder wear differences caused by 'the lazy V4' are responsible for the MpG benefit loss over time.
People who wait to change their oil until the OLM hits 20%, or less, accelerate the Engine Half @$$ lifters' demise.
Same goes for failing to assertively maintain the PCV system.
Sooner or later, one or more of the dual-mode lifters will fail / be failed, either by the oiling system itself,
contamination of same, or the inherent design flaws of the dual-mode lifters themselves.
Although this failure can be put off further into the future by disabling Engine Half@$$ at the first opportunity,
in the long run the lifters eventually fail (an Engine Half@$$ failure after 200,000 miles is impressive, but still ...)
If you haven't yet uninstalled the feature,
raise the V4 mode enable temp over 235F if you want to save it as a defense against overheating.
Otherwise disable it entirely by raising the V4 mode enable temp over 266F.
j91z28d1
honestly I blame gm for adding afm, not any regulations. gm tried this stuff all the way back in the big carb caddy motors. gm has always chased mph number, even in their base sports cars. they also tune their throttle Map to be much softer than say Ford. I think it's just in their DNA. they spent the money and effort to certifi a small bore 305 in a camaro with half the intake port in the head blocked off because it got 4mpg better than the standard 305 they already had clear.
it's just a gm thing
Marky Dissod
Cadillac's V8-6-4 shut off the fuel but did not shut off the valves
(nevermind that V6 mode was its own rumble factory),
which made the power loss and vibrations so blatantly obvious to the driver,
that the feature got disabled before it could cause any serious costly damage.
With Engine Half@$$ / V4 mode, GM hid all sensations well enough,
that there are still people who refuse to disable the feature today.
(After it fails, they'll try to sell it, no doubt ...)
CAFE MpG test scores hit every carmaker in the US market, but I agree that how GM handles it is also off-putting.
Particularly annoying is the undergeared axle ratios.
3.90 or 4.10 would suit me & my Z71 much better, and cost very little if anything in terms of highway MpGs.
j91z28d1
yesterday changed the first run of R&P. usually I do 3500 ish miles, this one was more like 4k because it was out of stock local.
what I saw was catch can that usually has just a few oz at the bottom, this time was over half full. and at the bottom was definitely gritty and gunk I've never seen before.
cut open the oil filter this morning, the media is still wicking oil off so I can inspect but it's very black looking. and bottom of the can had more of the same gunk the catch can did.
this engine I considered very clean for the mileage before, never took the drivers side valve cover off, which is normally the dirty side. but bore scope in the passengers side and oil pan looked very clean before, as well as under the vlom was just the normal red tint varnash. not sure where it's all coming from, but what I'm seeing would seem to be more than enough to plug up the filter under the oil pressure sensor if your afm is still active and had oil flow thru it. so might be worth noting you might need to clean that if you run 4 fills thru a dirty engine with active afm.
so far I'd say it's doing something. Will a slightly cleaner engine keep the afm valve train alive longer? I don't know but here to hoping it's helping not hurting haha.
why the catch can is much fuller too, I don't know. maybe it cleaned out plugged up pvc ports?
rdezs
My guess is it's dissolving carbon deposits.... hopefully from the piston ring grooves. That could increase compression with free rings, which could also increase vacuum, which could result in a PCV system working better.
I would think that AFM filter would be a concern in an active system that's not turned off. I wonder if the r&p keeps dissolving the carbon even once it's broke loose, into even smaller particles..... I would think so. Looking forward to your second third and fourth oil change....
j91z28d1
you might be right, it might just be gritty now and something that could clog. but maybe it could be broken down every further and wash away.
interesting.
my afm hardware is there but turned off in the ecm, and the oil port to the solenoids blocked off, screen removed and valley oil port gaskets clipped.
168k at this change, so we shall see.
pig mat does a good job of sucking the dark oil out so you can see what's left behind on the media
dirty side.
pulled tight so you can inspect
few little specks in there, but nothing out of the ordinary for what I'm used to seeing on engines(I cut open a lot at work) and much less than I find in my ls3 for years. so far so good
what was in the bottom of the catch can from wiping it out
j91z28d1
Kind of looks like dissolved carbon and varnish?
I could guess so. Just weird it would make it into the catch can. but yeah guess it's good to have, so it's but dumping it back into the intake.
I have a 2011 and just always figured I had the updated valve cover but I never pulled it to confirm since it catches less oil than my ls3 engine does that has the valley breather. but now I feel like I should just to see.
opfor2
Riverside County, CA
I too have a 2011, built in November 2010 and it DID NOT have the updated valve cover. I replaced the cover and now I have no more oil loss as I did before.
j91z28d1
interesting, I'll have to look at the build.date again. I never had enough oil use to show on the dipstick between changes. after adding the catch can here was some in there but not what I'd call a lot. so I just always figured it did.
I'm going to check next time I get a minute.
opfor2
Look at your driver's side door jamb sticker on the upper right hand top corner and it will show the build date. For example, mine is 11/10
a1parrothead
