992dr
Eastern N.C.
Hey, I just registered here but am having the same issue with my 19 Yukon. Did swapping a new trans fix the issue? I took mine to the local GM dealer and they said they done see any problems with the trans other than the code showing. I've been looking over @NickTransmissions thread on these as well
Hey how's it going? Welcome aboard :)
After changing the solenoid it helped a little but in the end yes changing my torque converter did solve my problems.
bobsburban
Need to wash and wax the thing, trailer as well. That paint is showing it's age (5 years) but I'm just going to wait a few weeks. We're just beginning the Great Pollenation down here. Probably just wash the trailer, get it detailed and the paint restored when we get back in August. Looks like that will become a regular every 5 year event; not safe to get on the roof any more to cover it up.
Sir_Hiro
Automotive Mad Scientist
Gave it wipe down with the spray wax. Downside of compounding a whole truck is the ungodly amount of it everywhere. Even after a power wash. Also discovered my barn find Uniden CB Radio I was going to put in the Yukon is dead..But I have a Motorola brand new in box to put in instead. Also C10 is Anxious for warmer weather.
Charlie207
LFOD, New Hampshire
Added 1.5" leveling blocks (the round kind) to the rear, to fix the squat after adding the 5100s to the front.
Ordered the wrong size rear swaybar bushings, but when I pulled out the current rears to replace and add fresh grease they looked fine compared to the fronts.
Charlie207
LFOD, New Hampshire
This sub-forum is for 2007-2014 SUVs. There is a dedicated 2015-2020 forum for yours, which may be a better place to ask.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
No issues with any of the bolts? One of my front ones snapped off on me when I did mine. I had to drill it out and use a nut and bolt.
Charlie207
LFOD, New Hampshire
Which bolts are you talking about? My rear sway-bar bracket bolts (the 10mm) came out fine. When I replaced the front bushings a year or two ago ??? there was a mighty struggle when one on them broke. I've since dropped a bit of anti-seize on them.
89Suburban
SE PA
Yeah those bolts for the mounting brackets.
Charlie207
LFOD, New Hampshire
Yep, one of the front guys snapped. IIRC, it was the passneger side...? There's is a pocket above the bolt hole that traps all sorts of schmoo, and rusted the bracket bolt up good. The old bolt was fused in there, and I ended up drilled out a few milimeters to the side, and tapping new threads, and the bit wandered a little and didn't go exactly through the middle of the broken bolt. The braket is still basically in the same location as originally.
89Suburban
SE PA
Yup same with me but on the driver's side back bolt. My damned bit wandered off center too so I drilled through half of the captive nut. Had to add a flat washer under the new nut so it would sit flush and used a nyloc nut.
RooTBeeRthe1st
Got hit and run again yesterday morning commute.
They got the worst of it ...wish I had a metal bumper, I might have been able to keep their bumper!
They ran up the off ramp during heavy traffic, had no turn signal on and jumped in front of me over the solid white line.
Left a tiny bit of white paint on the corner of my bumper, (basically wiped rite off, a lil wax will make it disappear. But they have a lot of black rubber from my sidewall on their rear bumper.
It jerked my wheel a bit.
mountie
Why I have a dash cam...
RooTBeeRthe1st
i have one too, i think i could find a clean frame with the lice plate too. But my cars seen much worse and i dont want to deal with that drama...however, i really want to file a police report over it just to give them a reality check. THey're lucky we were going so slow, I could have easily pitted them.
RooTBeeRthe1st
Mine have caught two hit and runs on me, a meteor burning up into the atmosphere, being cut off by a Mercedes changing lanes through an intersection in front of me... Probably a number of other things I can't remember
mountie
I have been using dash cam's for around 12 years or so, saved me a few headaches for sure. Mainly ass-hats trying to blame me for accidents that were not my fault in way at all
" The other driver lies"..... A dash cam requirement, to protect you and your insurance company.
"Hit and run"..... About 80% of small accidents . The dash cam assists the police.
" 80% "...... Includes parking lot bumps.....
Phlipnstik
