Let's Talk GMT900 DriveShafts !
Foggy
KS
I'm aware of the issues with the GMT900 driveshafts that like to fail/pancake out at
higher speeds... (from what I've read, anything over 95 mph for a short distance)
Obviously we don't drive race vehicles. But I do tow heavy and when not towing have
gone a tad over the speed limit at times.
Anyway... Is there a difference from year to year ?? Mine is a 14 (last year of gmt900)
My driveshaft - REAR is made of steel and about 3.75" outer diameter. And I'm sure
it's the longest of the AWD/4WD since I have an XL model.
Of course a 2WD would have a longer one.
Let me know of info that you might have. I'm thinking I need to upgrade my shaft ! Just
don't know which way to go or IF needed for sure for my year.
Marky Dissod
What are the differences - if any - between the civilian driveshafts and the Z56-PPV driveshafts?
j91z28d1
I thought they were all aluminum. Definitely some differences then.
by pan cake, do you mean the shaft itself fails at 90? that's not great. the speed limits here are 85. I've definitely cruised past 90 before.
intheburbs
SE MI
News to me. Guess I'm just lucky.
I've cruised for hours in the AWD Denali at 90-100 when I'm out west in those big states. Ditto for the Suburban, maybe even more so, and I had it as high as 116.
F
Foggy
KS
Yuppers. The limiter is also set around 90 mph due to the speed rating of the
tires. It's all about the lawyers !!!
I've seen pick of the bad ones. They kinda start flexing and then go oval.
That's what I mean by pancake. Then they just twist up like a pretzel
I thought they were all alum too (the rear driveshaft)
Mine is definitely steel cause it has some light surface rust
F
Foggy
KS
I have too. Not for any amount of time/distance. Just short bursts.
But the more I've looked into it.... it's very very risky
couldn't even tell you how many hours I have spent WELL over 100, more than almost anyone than a race car driver.
never had a drive shaft issue obs, gmt800, gmt900, k2
only time I had drive shaft issue's is when changing the original u-joints, ended up buying a dorman shaft, which they make on order brand new.
That being said can't say I have not considered having a "good" one made just never bit the bullet and did it.
lol I should have a "flight book" I certainly have a ticket collection.
j91z28d1
damn. that would be a hell of a reason to be stuck on the side of the road.
maybe less so with your steel drive shift?
I heard a ever so slight hum from mine at highway speed a few months back on a trip. I still fear it's a u joint going. it you find a good shop to make you one that's actually smooth. Definitely let us know. I'd spend good money to not have to deal with that crap. but mine being a totally different tranny and all. I'm sure it would be totally custom.
my next step was to find a used one somewhere to try
Marky Dissod
The limiter is also set around 90MpH due to the speed rating of the tires.
It's all about the lawyers!
Actually, sometimes, the tires, and the speed limiter, are selected in context of the driveshaft's 'critical velocity'.
I've seen pick of the bad ones. They kinda start flexing and then go oval. That's what I mean by pancake. Then they just twist up like a pretzel.
What actually happens is more like ...
How much margin does a driveshaft with a diameter of, say, 4.0" require around it for safety reasons, so long as it is operating properly?
Beyond a certain road speed, the driveshaft is spinning more RpMs than the engine.
Problem is when OE is not willing to spend enough on quality construction / balance of driveshafts.
Depending on how much evenly distributed mass a driveshaft is made of, if you spin a driveshaft too fast,
it eventually starts acting like a guitar string AND a jumprope, SIMULTANEOUSLY.
Often the driveshaft's inherent IMbalance is effectively less than the vehicle's potential top speed.
Apart from the thorium-footed Doubeleive, most of us almost never exceed 85MpH with our suvs (especially with anyone else riding along).
Those Z56-PPV Tahoes definitely have superior driveshafts ...
F
Foggy
KS
From what I understand, It's just a speed/ critical speed issue.
So if you don't plan on cruising at 95 mph+ alot, the factory one is fine
Of course new 1350 solid spicer type u joints and a balance job is always
a good idea. Our rigs are all 11+ years old now !!!
j91z28d1
only thing I can add is just for curiosity sake. my drive shift measures about 40 1/4in from middle of u joint cap to middle cap. I believe you're supposed to measure from flange to flange. but I'm not pulling it out for that haha.
2011 hybrid yukon with the 2ml70 tranny and 4x4 transfer case bolted on the back. what looks to be a 3in Dia aluminum one.
Marky Dissod
From what I understand, it's just a speed / critical speed issue.
So if you don't plan on cruising at 95MpH+ alot, the factory one is fine ...
GM OE for the PPV would be better than fine - and it'd still be 'factory'!
F
Foggy
KS
To update some info: I talked (finally) in person to a reputable driveshaft
shop that does custom/racing/hotrod shafts.
I described what I've got now and what would be needed to upgrade or
prevent a future issue.
My current driveshaft is approx 55" from UJoint center to UJoint Center and
approx 60" from trans case face to differential face. It's 3.5" in diameter and
is STEEL.
The shop I spoke with said there should be no issues even at speed with
the short of a driveshaft that is 3.5" diameter Steel.
So maybe there were some changes in the GMT900 platform as the years
progressed.. IDK.
But I'm just going to replace my Ujoints with the Spicer solids - 1350- series
and have it balanced
The RWD Suburbans, Yukon XLs, Avalanches and Escalade ESVs and EXTs all use a 1 piece aluminum driveshaft.
The 4x4 Suburbans, Yukon XLs, Avalanches and Escalade ESVs and EXTs all use a 1 piece tapered steel driveshaft.
All use 1355 universal joints and yokes for the rear shaft.
The front shafts are steel and use 1344 universal joints and yokes. The shape and diameter of the tubing between my 2009s front driveshaft and the ones in my 2012 and 2013 pickups are different.
The front and rear driveshafts ought not to exceed 5,000 rpms, that's shaft rpms, not engine, lest they destroy themselves.
The GMT900 and K2 pickups with the 1 piece aluminum driveshaft are notorious for twisting them to pieces when they hit the magic speed of 112 mph.
This is the data I've gathered over the years and it has not been peer reviewed:
These comments generally exclude the 2007-2008 SUVs as I believe they were still using the previous generation's components. Can't recollect with certainty.
F
Foggy
KS
Thanks for the extra info swathdiver
The UJoints I purchased and am going to use on my rear driveshaft
are a 1350 series U Joint. IDK if the 1355 you mentioned is the same or not.
I don't think I've ever used a 1355 series
Marky Dissod
These comments generally exclude the 2007-2008 SUVs, as ...
The previous generation's component of concern is the 4L60E.
The vehicles with 6L80E obviously used different shafts.
The AAM 1355s are different but the Spicer 1350s work fine when thinner snap rings/clips are used.
F
Foggy
KS
Where do you guys purchase your u-joints from?
Any reputable parts store is fine. I think I got mine from rockauto...
Just don't buy the cheap ones. The spicers/dana type solid Ujoints
are the strongest. They don't have a greasable zerk built into them.
That makes the body stronger, but you can never "service" them. They last
a longtime though. I do solids whenever avail vs zerk type ujoints
As an added note: I purchased the Dana 51350X Ujoints for my rear shaft
HeavyHoe03
