Denalis stopping while driving- class action suit?
jfoj
Assume the replacement vehicle has a 6.2l?
So if you do not want this problem to occur again, I would suggest you do the following, which I am doing.
1. Run ONLY Premium fuel in the vehicle,
2. DO NOT use the remote start feature or start the engine to allow it to warm up, especially in the colder months, or in the Summer to cool off. Start the engine, allow the RPM to drop down (20-30 seconds), put the vehicle in gear and drive it.
3. DO NOT use the Auto Stop/Start feature. Suggest you get a Range DFM disabler, about $250, it disables the Auto Stop/Start feature and disables the DFM while under load. The other option to work around the DFM at least for most daily driving is put the transmission in L9 rather than D. This eliminates DFM around town up to about 50 MPH without much loss in fuel economy. But you will want to run the transmission in D for the highway, but the DFM would be active in D without a disable device.
4. DO NOT allow the OLM to go to 0%, change the oil at 50%, which is around every 3000 miles.
5. DO NOT use 0W20 engine oil, use 5W30 or 0W40. Especially if you tow or load the vehicle with more than a few passengers.
6. Run 9 quarts of oil with filter change in the engine, 8 quarts is not enough even though all the documention states this. These engines require at least 8.5 quarts, but 9.0 will not hurt the engine.
7. Check the oil level on the dipstick every 2nd fill up, the low light comes on at 2 quarts low.
8. Install a catch can and monitor and empty on a regular basis. JL Catch Can is a very easy install. There are others, but the JL seems to work fine.
I am sure there will be a LOT of comments, but I have been doing a lot of research on these failures and this is all you can do to counter any possible future failures. The biggest problems is 0W20 engine oil that becomes fuel diluted and not running Preminum fuel. Almost all of these engine failures have been oil related, a few have been due to piston wrist pin locking ring problems. Almost all of these engines have failed while cruising on the highway as well. Low oil, fuel contaminated oil seem to be a reoccuing theme.
Let the comments begin!
KMeloney
@jfoj — A not entirely rhetorical question: At this point [in the course of all of the failures], why wouldn’t GM make the same recommendations? (Never mind the auto stop and DFM overrides, as I’m sure they can’t recommend things that defeat their integrated systems.) They’ve already acknowledged (quietly) that they’ll replace seized engines, so I don’t see why recommending higher visc oil, or limiting warm up time, etc, would be detrimental for GM to embrace and promote — especially if it staves off engine failures and replacements.
Yes, a big part of me wonders if those recommendations are NOT beneficial. But I’m just trying to learn as much as I can about all of this, and don’t have enough knowledge to say who/what is right or wrong.
I certainly appreciate your continued search for the answers here.
jfoj
KMeloney, I appreciate your interest to learn and understand. We are and have been sold a bill of goods for a long time. Ever since GM moved away from the older 6.0l in the mid 2000's we have all been forced to SUFFER with AFM, 0W20 engine oil, Auto Stop/Start and all sorts of other foolishness and we are all paying premium money for stuff that is unreliable, breaks often and way too expensive and time consuming to repair. An we are all supposed to like this and smile about it! Even the 6.6l gasoline engines are having failures without the AFM, but they are DI and fuel dilution of the engine oil is a common denominator even with a higher viscosity oil spec for the 6.6l, but these engines are also probably pulling heavy loads on towing on a fairly regular basis.
GM cannot just disable, take off, or recommend the owners do things like turn off the Auto Stop/Start. Just turn off the Auto Stop/Start, the feature does not hold the setting when the engine is turned off, you have to turn it off EVERY time you start the engine. EPA, CAFE and governmental regulatons are all forcing the auto manufacturers to features/add ons like the Auto Stop/Start and DFM. In order for the manufacturers to try to increase fuel economy, they added the Auto Stop/Start and DFM system along with multispeed transmissions with multiple overdrive gears and moved to 0W20 engine oil. But even if GM indicated they should be disabled, we all paid extra for this garbage! None of these things were really added to increase reliability and longivity of the vehicle as this is not as much of a priority as fuel ecomony and checking some boxes that the government required.
Here is the real problem, todays DI gasoline engines while having a much higher power density than older port fuel injected engines really have problem with fuel dilution of the oil. Many 10-20 minute short trips are also likely to keep the oil from getting up to temperature as well. Keep in mind you may start out with 0W20 engine oil, but as fuel is mixed in this oil, the viscosity drops and with the high torque peaks on a regular basis, the fuel diluted oil is just not going to protect the engine. The only way to even start to cook out any fuel in the engine oil is the engine will need to be driven probably at least for 30 minutes at a minimum and more likely 45 minutes to 1 hour. If you tow with one of these trucks or load up a family of 3-6 passengers and all the associated gear, I would not want to rely on 0W20 oil at all.
GM and other manufacturers have provided high power keyfobs and Apps that allow you to remote start your engine and allow the engine to run for up to typically 15 minutes to warm up or cool off the cabin. Doing this is dangerous to any engine, but really bad and tough on DI engines. So if the manufucter tells you not to run the engine for 15 minutes before driving, then why did they give you all the remote start options? Sure you can walk out and start the car as well without the keyfob or App, but you are less likely to do this. I am surprised the government has not outlaw the remote start features due to additional fuel useage and emission output!!! Might be coming to a town near you in the futurer?
Every 10 years in the auto industy there appears to me major changes that impact how and engine is built, operates and runs as well as often some of the changes reduce the reliability and lifespan of the engines. Start back from 1960 and follow each decade and you will see all the changes, many have not been such great ideas. Then the marketing starts to extend mainteance and oil changes. Hell today you have oils that claim they can protect your engine for 25,000 miles and oil filters that claim they can last 20,000 miles. This is not happening on any of my vehicles, especially any of the DI gasoline engines. I am changing oil about every 3000 miles or when the OLM hits 50%.
The problem is nobody drives vehicles under ideal conditions and even if they do, I guarantee you 5-10 years from now everyone that is knowledgeable will say that running oil changes out to 10,000-25,000 miles was foolish! What most people do it put their engines through hell and do not even realize it. What you used to be able to do for your port fuel injected engines is really bad for a DI engine.
As far as Premium fuel, nothing in the owners manual that I can find, probably because the owners manual are more generic these days and often there are different engine options. Just swing open the fuel door on your 6.2l and look at the sticker that states "Premium Fuel Recommended", it does not say required, it say recommended, but with LSPI (Los Speed Pre Ignition) so prevelent in todays DI engines with high compression and/or turbo charging, this is really a must. The 6.2l has a compression ration of 11.5:1, I only had a few cars with modified engines back in the day that had compression rations higher than the 6.2l. Extened LSPI can hammer the rod bearings out of an engine and also break piston rings and also damage pistons. Do not be fooled that LSPI is only a problem with turbo engines, the 6.2l rarely runs above 1700 RPM on the highway and the high torque during grade climbs makes the conditions ideal for LSPI, even more so with fuel dilution in the oil.
So I will try to let the data speak for itself. I have been looking at how GM implemented the current 6.2l in these latest round of trucks with DFM and it is crazy how low the engine RPM is on the highway and how much torque the engines are putting out to hold the speed on the highway. Also understand how long it takes to get approximately 11 quarts of engine oil up to at least the engine temperature and even above the engine temperature. 30 minutes of driving at a minimum at temps 50F or below. I have not had a chance to gather data for higher ambient temps yet, but assume at least 20 minutes of driving at 70-80F, again data will show what the timeframe would be.
Suggest you go look over this post in a thread that I provided a lot of data in - https://www.tahoeyukonforum.com/thr...0-000-gm-vehicles.152506/page-29#post-1949528
As far as wondering about Premium fuel vs Regular fuel, I have no data on Regular fuel and I do not plan on gathering it on my vehicle, but look at this graph that is for a 2 hour, 15 minute mostly highway cruise on a reasonable flat area, there were some grades, but nothing major and notice the amount of spark retard in the blue. The red is the engine torque while cruising, notice the amount of torque useage above 75%. While the spark retard values are not signifigantly high, just think about if Preminum fuel was not being used. BTW this is 93 Octane, however, I also realize some areas in the US may only offer 91 Octane as Premium.
Forum tip: don't forget to use the "tag" feature if you want to be sure your target sees the post, or use the "reply" feature like I did here.
To tag someone, start by typing the "@" symbol, then (without a space) the start of the member's name, like this: @KMeloney. Then select the member's name from the picklist that appears.
j91z28d1
curious where this graph come from? if you're able to log, and you log knock count. not they timing retard. there's a lot of retard tables in the tune, anything don't burst knock, to activity knocking.
I do agree, if your dead stock di engine is knocking on 93 just driving around normally. it's not going to be happy 300k miles from now, if it makes it
jfoj
Pulled data from my vehicle via ODBII port and then had to work to graph it.
Unfortunately I do not have knock count reporting at the moment, still trying to crack this one, but the fact there are so many "Knock Retard" events and they are in fact called "Knock Retard", I feel this is indicative knock events and could be a much a bigger issue for people not running Premium fuel.
Understand most of this driving was while operating with cruise control enabled as well on reasonably flat highway, so likely a bit more subtle throttle response than my right foot.
Agree there are other timing retard events that may not be due to knock sensing. See more below along with graph.
Below is a scary graph of a timing table that is pulling 30 degrees!! of timing during tip in throttle and under heavy load. Notice the "Knock Retard" is flatline across the bottom and is not a contributor to the timing being pulled. I cannot image how much power it being lost due to this timing behavior. BTW, this is all with the engine RPM never exceeding 1700 RPM! Cruising at around 70-75 MPH while pulling a slight incline on the highway. Transmission typically never shifting out of 10th gear.
A pretty good source that did some advanced testing on this later generation engine led me to believe this was GM's way to help reduce/eliminate LSPI. But this is a rather radical reduction in timing at 30 degrees. I feel there are errors in the timing maps based on what I am seeing. I dealt a lot with this back in the early 2000's with a number of manufacturers and this was actually a major error on the manufacturers part.
Not in this instanced where I have captured the timing pull under heavy load, but under other driving conditions, other radial timing pulls usually can feel like misfiring during tip in throttle under light to moderate load. The issue is not misfiring, it is power pulses due to the dramatic loss of power when the timing maps are being switched in and out. I can feel this power pulsing happening in my truck, it is not DFM, it is not Knock Retard, it is timing maps switching on and out causing the misfire sensation. No misfire indications at this point either. Again, the graph below is not indicative of the timing map switching causing power pulsations.
This graph is just an example of how the timing map can pulling timing without a knock event as there is no "Knock Retard" contributing to this event.
j91z28d1
I guess these are global b or whatever they are calling the new ecm's that haven't been cracked by hptuners yet?
try looking for cam timing, and see if it's retarding the timing because of the vvt retard.
there's so much going in in these di engines. you need injector timing event as well.
expensive test but if you can find a pump in your town with 100 octane unleaded, or they say vp fuel has a good booster that actually works. guys use it for extra safety doing dyno runs for 93 tunes. if the retard goes away, you are definitely on to something. Sadly I have no idea how to fix what yours seeing.
could try a good catch can, in hopes it's sucking in some pvc oil causing knoc?
jfoj
No, 100% stock except for a catch cap and Range AFM device. At some point I'll likely pull the range device just to make absolutely sure it's not contributing to the timing map behavior but based upon what I've been led to believe there is a lot of that programmed in to the stock ECM.
j91z28d1
yeah. interesting.
good luck with it man. are these flex fuel for e85? that's got a high octane rating. might help rule out if it's real knock or something in the programming.
WalleyeMikeIII
Sunny and Snowy Minnesota
It is actually in there, at least in the 2022 model, see below.
I did note that from 2021 --> 2022 the recommended octane was dropped from 93 to 91, probably a marketing thing, since some states only require "premium" to be a minimum of 91 (perhaps elevation related), Minnesota, where I live, is one. I have found 2 stations in town that have 93 and Costco is 92 here. I have been running from Sinclar's 93, unless I am in a pinch on the road, where sometimes all I can find is 91, then I go with that, since it is all there is.
Note the advice is pretty "loose" in the OM. Says 91 is "recommended" but then says if you can't find premium, use 87 mininum. Then, under "prohibited fuels" it says any fuel that is not the recommended octane. Great documentation.
Net, I have never run less than 91, and mostlly 93 in mine..have shared this w/ friends, and they too have only run premium. Not sure if this will mitigate all the issues, but anything that eliminates knock has to help.
tagexpcom
I've used "Regular" (87 octane) in my 2021 Yukon Denali 6.2L a couple of times. First couple were before I read about the higher compression / engineering that makes "Premium" (90+ octane) strongly advised for proper running. I also found that I could not make it towing a trailer from Lakeview OR to Winnemucca NV (where there's only 1 gas station with "Regular" only) along the way without carrying 5gal of "Premium"!
The couple of times I used Regular I didn't have noticeable issues except a loss of power accelerating up a long 6% grade while towing... the rig topped out at ~60-65mph and wouldn't accelerate any more with foot-peddle all the way to the floor - which surprised me as this doesn't happen with Premium.
The engineering, higher compression ratio explanation + towing experience has pushed me into taking "Premium" recommendation seriously enough to carry that 5gal can to span the long distances without gas stations in the high dessert.
jfoj
Full Manual available for download here
Hey, I looked at what was included with the vehicle, never really worried about online manuals when I have the printed one!
Will be interested to see if the online manual is double the pages as the one included in the vehicle. Must have been another fuel saving idea?
Online manual is 288 pages more than the printed manual in the truck, go figure.
jfoj
@tagexpcom
Scary about the 6.2l WOT and topping out at 60-65 MPH. May be a factor of weight, wind resistance, elevation and grade?
But look back a bit earlier in this thread where I have the Load and Timing where the timing was retarded by like 30 degrees, this probably equates to like a 50+ HP loss probably impact torque a bit more. I wonder if you were pushing into having the timing pulling 30 degrees like what I found. This would clearly be a reason the engine is topping out on top of all the other variables.
WalleyeMikeIII
FWIW, the digital copy of the manual is also available on the infotainment screen in the MyGMC App...so, in a way they did give you a copy...it is 2025, after all :rotflmao: The main reason I know about the electronic version is I ordered my vehicle, it was back when it was a long wait to get one...so in the meantime, I downloaded the online version and read it, while I was waiting on my vehicle to be built and arrive. I do like the electronic version, as you can search it, and it is hyperlinked...so makes navigating it a bit easier.
tagexpcom
@tagexpcom
But look back a bit earlier in this thread where I have the Load and Timing where the timing was retarded by like 30 degrees, this probably equates to like a 100 HP loss, unsure in Torque, I wonder if you were pushing into having the timing pulling 30 degrees like what I found. This would clearly be a reason the engine is topping out on top of all the other variables.
You're right - there was a significant (20?mph) headwind and it's a 5400lb cargo trailer - basically a square box and the drag greatly increases as the wind flow speeds up - so maybe 65mps + 20mph headwind is like trying to do 85mph and still accelerate? Was a steep (at least 6% grade), many mile uphill mountain road, likely 5000-6000ft elevation. In this area of Eastern Oregon....
I was surprised as I hadn't had this happen before with Premium - so I'm guessing it might have been the 87 Octane along with the wind and full 65mph and 6% grade tipping things over the edge? but I don't know for sure and don't plan to experiment.
jfoj
@tagexpcom
You were testing out the 6.2l for sure. It is crazy how a trailer is like pulling a sail down the road. Even on my 2005 6.0l pulling an small, empty enclosed trailer it killed the fuel economy on my 6.0l, was down to 10 MPG! I bet with 87 the thing was knocking up a storm and pulling timing.
I hope your 6.2l holds up. I would not be running 0W20 towing with one of these engines.
Would have been interesting to see what the engine oil temps were running.
