Eibach 38106.320 sway bars.
Walkerfever
Missouri
Hey guys,
I found a deal for both front and rear sway bars for $250, but I can't find any concrete answers on if it would fit my 2019 Yukon. Anyone know for sure if they'd fit? I know the Hellwigs would be better, but at $250 for this set...would it be worth it?
Thanks for any input you have!
Edit: Whoops, this got posted in 2021+, would a mod please move it to the 2015-2020 section?
Hey guys,
Do you have any part numbers or other details on what you bought so that we can help you determine if they'd fit?
W
Walkerfever
Missouri
It's an FB marketplace posting, it shows 38106.320 on the listing. I did some searching and found this thread, but didn't really find a concrete answer on it: https://www.tahoeyukonforum.com/threads/has-anyone-upgraded-sway-bars-yet-on-15.100100/
Here's the pictures from the listing:
Does your Yukon have Autoride?
Then it should work. Your 2019 Yukon will be the same as Tahoe and it says that 15-20 Tahoes work as long as it doesn't have Autoride. So you should be good.
W
Walkerfever
Missouri
I saw that it had listed 2WD, just wasn't sure if the 4WD would matter.
In my experience the 4WD aspect does not make a difference and they use the same sway bars regardless for 4wd vs 2wd. I'd jump on the deal and not look back :waytogo:
W
Walkerfever
Missouri
I guess that last sentence answers the "Is it worth it?" Question, lol. I would love to get some Hellwigs, but I'm thinking that the price savings on this deal makes up for the Hellwig's benefits.
I would agree with you. Hellwig's are nice but with the price savings you're getting on the deal I think it's worth going to the Eibach. You can always upgrade to Hellwig later if you still really want them.
W
Walkerfever
Missouri
Agreed. Now for a 4 hour road trip, if the seller responds. Looks like it's up in your neck of the woods, in Riverside.
That's always a question mark is getting a seller to respond. Non-responding sellers is why there's such an annoying problem with "is this still available?" because so many people just leave their ads up once it's sold (or they decide they don't want to sell). It's annoying LOL
W
Walkerfever
Missouri
Heard back, but someone else is interested. Damn the luck. I'm next in line though.
Hey guys,
**EDITED**
short answer is the front sway bars are the same for all 07-2020 1500 suv's 2wd/4wd/awd, with or without autoride (doesn't matter)
THE REAR apparently is different for 2015-2020, 07-14 have different rear part number
the front is also the same for 07-18 1500 pickups (or 2019 LD), the rear is obviously different because they have leaf springs instead of a floating rear axle
2019 and up on the pickups (front) is questionable haven't looked to see what was changed up front if anything.
different for 2021+ suv's (complete re-design)
skid plates are the same for 07-14 suv's & and up to 2013 on the pickups (unless they made a LD)
skid plates are the same for 2015-2020 suv's and up to 2014/2019 on the pickups (there was a 2019 LD)
the only difference here is on the pickups 2014 was a early changeover year so 2014 was the new design for them (skidplate wise so they would get the 2015 version)
in most cases also if the vehicle is lifted or lowered the same applies you just need the correct brackets/end links instead
I edited the above, rear is different for the k2's (15-20) front is the same 07-2020
what the actual difference is I don't know haven't experimented with trying them
from pictures they look fairly close the endlink holes are wider, perhaps due to vehicle height differences from the gmt900 to the k2's
top is 07-14, bottom is 15-20
the hellwig endlinks are adjustable so unless the bends are different horizontally then you could probably make it work either way
W
Walkerfever
Missouri
Heard back from the guy, and looks like I might be going up to get them on Sunday. Not sure what time he will be available (He's out of town), and if it's too late I won't have enough travel time. I did notice that there might be one missing bushing, but I should probably replace them any ways. Any one have any input on that? I might end up ordering them ahead of time.
W
Walkerfever
Missouri
Well, Sunday fell through, I guess he was out of town for work. We are currently set up to go up there this Saturday, we'll see. I already have new Moog endlinks ordered, just need the bushings...but I'm waiting until someone can drop some part numbers\measurements here or I have the bars in hand to measure.
W
Walkerfever
Missouri
Rear bar is completed. I used some stock Moog replacement endlinks, and Moog K7326 Bushings. Everything bolted right in. What a difference! I haven't sourced front bushings yet, but once I buy those I'll be installing the front bar.
jk6062
