2008 Escalade - rapid clicking no start
Mordechai
Hey guys. Really feel stuck.
Already tried new OEM positive and negative battery cables, new oem starter, new battery, new ground cable from firewall to back of head on drivers side. Mega fuse cleaned and tested good. Cleaned frame behind bumper where battery grounds. Tried to jump start from a good running car. No dice.
I was able to start it once by hooking a ground cable from battery to starter directly but it doesn't work anymore. Mightve been a coincidence.
Any ideas where to go from here?
Thank you
Thank you
rapid clicking generally means low voltage (to the starter), so do a "drop test" on the starter cable (which you have not yet replaced per notes above?)
if the voltage at the starter (while attempting to start) is 10.5v or less, then the starter power cable is bad or battery is low voltage. or it needs to be cleaned at the contact points
Have you verified that the battery is not discharged?
Put a voltmeter to the battery and measure its voltage and cross that with the ambient temperature outside to get an idea of the battery's state of charge. If it's below 65%, it's no good. Since it is new, you may just need to put it on a tender overnight to charge it up.
Mordechai
Mordechai
Wouldn't it start when jumped with another running car in that case?
Not necessarily. A good ground connection is critical and hard to get with many cables and a discharged battery needs the donor car to be revving the engine well above idle for a few minutes.
Mordechai
Mordechai
So is the battery toast? This is after trying to crank it a few times
Well, that little doohickey says the battery is good but discharged. At 11.69 volts is definitely dead.
Do you have a battery charger or tender? If you need the car for work tomorrow, charge it at 10 amps and it should be ready around midnight.
do the drop test if the voltage is good as I noted already then it's something else, it's a troubleshooting process to find the problem.
the battery is low now but the drop test still needs to be done (with a good charge)
Mordechai
Mordechai
I don't have a charger. Just a jump pack that has jumped diesel semis and another car to jump off of. I'm guessing that isn't enough because it does the same thing with both of those.
Never heard of that and the idea of dropping a 45 pound battery scares me! LOL
A battery tender can usually rejuvenate a dead battery, I've done it.
voltage drop test, this tells you if the starter cable has high resistance, burnt, etc.
mine on the yukon has been fine but on the silverado that thing looked like someone tried to cook it on the bbq and it was 7 years newer
Mordechai
Mordechai
Here's a video. Also I found a voltage drop! Hooking up one lead to the starter casing and the other end on the battery negative I get what you see in the video. Looks like massive voltage drop. Problem is, i'm not sure where to go from here because testing with one lead on battery negative and the other on the ground that's on the engine that comes from the battery, there's no drop. As far as I know that's the ground the starter/block uses because i'm not seeing anything else. Other than the strap going from the back of the head to the firewall on drivers side which is new. Unless i'm missing one. I know the 5.3 has one hiding behind the PS Pump but the 6.2 doesn't so not sure where to go from here.
What's the voltage of the new battery?
JasonW4141
