Lowered 21+ T1xx: Post Em Up
DaveLaz
Thanks, did the front drop spindles hurt the ride any?
That's the thing, in theory, drop spindles "shouldn't" hurt the ride, as the geometry of the strut compression, spring rate etc doesn't change. But I absolutely felt a difference in the ride. That being said it was kind of hard to tell how much of what I was feeling was from the rear, where I had drop struts.
DwDrummer
AL
That's what scares me when I talk to all these suspension shops they will say oh it won't hurt the ride or it might barely stifen up the ride but nothing too noticeable. I guess some people are just more sensitive to the ride than others. Did the lowering spindles make it take bumps in the road more harshly?
DaveLaz
Yes but again, I may have experienced a harsher ride because of the combination of having rear drop struts. I think with rear lowering arms, it would've been better. Streets play a big role as well. I live on Long Island and it's awful by me, just terrible. If I lived in Florida I probably would've never felt a difference in ride quality at all.
juice1s
Cicero,il
Slammed 5 inches in front and 7 inches in the back, plus an extra 1/2" when the subwofers are in.
juice1s
Cicero,il
I've strongly considered lowering my 24 Tahoe RST 4WD ( non mag ride ) 2" all way around and have been told to use Belltech drop struts, then was told not to use those because it would hurt the ride to go with Maxtrac drop spindles/adjustable rear lower control arms. Can anybody confirm which would be the best and not hurt the ride?:D
11
Thanks,
DW
Hey man, the maxtrac rear adjustable lower control arms are a nice ride but they sit too low and you will scrape on everything (know from experience) maxtrac drop shocks will give you 4 in drop in the rear and rides pretty smooth
KMeloney
juice1s
Cicero,il
Hopefully you're somewhere warm where you never get snow. Otherwise, it looks like you could plow my driveway with how far those MaxTrac components hang down!
Whatever the case, the truck looks GREAT.
Unfortunately chicago area they do sit very low but I switch them to stock in the winter, raises it about 2 inches. Thank you
lakaw
Wichita, KS
KMeloney
If you get a chance, could you measure the clearance between the trailing arm and the ground? LOOKS like about 2".
I only want a 2/3 drop. Will this result in the trailing arm being higher off the ground than what you have in your setup?
Is that your truck in your avatar pic? If so, where are full pics of it in the '21+ section?!
lakaw
Wichita, KS
It is!! it's the only pic I have currently. I want to get it lowered before posting pics. Weather is ****** here, so it's going to need a detail too. Where is everyone posting pics?
KMeloney
Wherever you want! Start a new thread in General, or post a pic in the “black wheels” thread in Exterior, or put one in any thread about roof racks… JUST POST SOME PICS!
juice1s
Cicero,il
I don't remember the exact measurement but it was a little bit over 2". The arm will sit a little bit higher if you do not go that low but not by much.
olyelr
Elk Rapids, MI
The lower control arms will change a little bit, but they only go up and down with height changes on the differential side…at the tires they stay the same height (unless you change tire size).
spartan1984
Hi all,
Dropped off the rig at one of the local shops to add the Belltech lowering kit (1105SP) as well as switch out the OEM exhaust for the Borla Cat-Back Exhaust/Touring with black tips (Part# 140854BC). Only lowered it about 2 inches (back and front) and the exhaust sounds sweet. Also added a Console Shield Cover (with black knob) as a nice clean look to the interior.
Barry & Shelly
Reaper21
How's the drive with the Belltech struts? I'm coming from a Jeep Grand Cherokee SRT with a tight/firm suspension and the softness and body roll of the Tahoe is killing me. Putting it in Sport mode improves it a bit, but I need more.
a1parrothead
