strutaeng's 04 2500 4x4 project Suburban
strutaeng
strutaeng
Dallas, Texas
Well Saturday my oldest daughter had a championship M.S. varsity volleyball game. Unfortunately, they lost. Got home and they had 50% chance of rain, so all I did was wash and held off masking. I did an engine oil change instead. The drain bolt was super clean. Of course, it didn't rain on Saturday after all, LoL. But Sunday we got a downpour.
Tonight I dropped the transmission oil pan. I started loosening the bolts and ATF started dripping everywhere. This pan doesn't have a drain bolt. I grabbed a drill and drilled a small hole where the drain bolt would go (I have another drain pan with the drain bolt laying around to swap.) Kinda of a pain actually to remove though. I realized towards the end the crossmember has these holes to slide a 1/4" ratchet and put a socket at the other end to remove the rearmost bolts.
strutaeng
strutaeng
Dallas, Texas
Got the other transmission pan reinstalled. I couldn't get the rearmost pan bolt: tried and tried and finally gave up. I removed the crossmember.
I drilled some 'ol holes and cut some reliefs on the transmission mount. Hopefully next time I replace the transmission fluid this would be a bit easier.
I just drained the transfer case and this is what came out. It looks and smells like ATF. I believe this transfer case requires some blue-looking fluid. I already dumped it, but that only looked like 1/2 quart. :-(
strutaeng
strutaeng
Dallas, Texas
If it's an NP8 RPO NP246 two-speed case it takes just short of 2 quarts of Auto Trak II (yes, it's blue).
I'll double check the RPO code on the glovebox, but I'm pretty these SUVs were only offered with that transfer case. It has the round pushbutton with "Auto."
strutaeng
strutaeng
Dallas, Texas
There should be a round badge bolted to the case unless it's been removed.
EDIT: I'll bet the TC is ruined if they used tranny fluid in it; might need a rebuild.
Umm. When I bought the truck the owner's son told me it was stuck on 2Lo and that's how they had been driving it.
I checked underneath and wiring harness to the transfer case motor was severed. I respliced everything but still nothing. Then I replaced the little reluctor wheel on the motor (I can't remember what the part is actually called.) That fixed the problem. TC works from 4LO, 4HI, and the Auto function. I confirmed by jacking the rear end on the air and I was able to pull forward.
I just drained the fluid from the pan and didn't find any glitter or clutch material. My understanding is that the NP246 uses some clutches similar to a transmission (actually shares the clutches with some Dodge transmission?) This is my old transmission pan where I drilled a hole, hence the duct tape. LoL
I guess I need to figure out what to do now? For sure I'll be at least replacing the correct TC fluid.
strutaeng
strutaeng
Dallas, Texas
Also, my Dad and brother were here to morning. My Dad's OBS truck had the fuel level sender go out so they needed my engine hoist to lift the bed.
Anyways, I had them help me install the hood. The color looks like a pretty good match. The only thing is on one side the hood is bent a bit and I didn't realize it. Oh well, probably happened from it leaning against my shed for several years. I'll order a bug flector and it should be fine. :)
It was super windy today so I didn't even try to paint the roof. And we are supposed to get a cold front later this week. Doh!
nsogiba
WNY
Hope the transfer case holds together! Glad you caught the fluid issue.
And yes, that rear trans pan bolt or two are a total nightmare to get to. I was able to snug them up with a combination wrench but no way was a torque wrench and socket going to fit.
Paint match looks great!
strutaeng
strutaeng
Dallas, Texas
I ordered the blue fluid. Should be here on Friday. I'll do the front differential next. I watched a video and it looks pretty easy.
I've got a 14 bolt 10.5" 4.10/G80 I had bought to swap into my OBS, but I think I'm going to swap into this truck, since it's literally a direct swap. These 6.0 have the 14 bolt 9.5". Mine also happens to to be 4.10 ratio.
I think I'll attack the headliner next. I've never done that job and it actually looks like a bear. I'm thinking I'm going to cut the wiring and install quick connects to avoid getting into the lower wiring harnesses. I've got a gun with the 1.7 and 1.9 mm needles, so I think I'm good there.
My brother pointed out that I should consider ordering the darker gray headliner to match the pillars (I had not realized that the headliner is actually a lighter color than the pillars until he pointed that out.) TBH, I've never been a fan of the 2-tone interior. The first time I saw it when I bought these suburbans 4 years ago, I thought someone had swapped interiors and was mismatched, LoL.
I think it's the "smoke" color the one that matches the darker gray, no?
strutaeng
strutaeng
Dallas, Texas
Thank you! Definitely a good learning curve to do automotive refinishing. But everyone has to start somewhere, right?
strutaeng
strutaeng
Dallas, Texas
I got the Smurf blue stuff in the mail today. I filled the TC by sticking a 3' piece of clear vinyl tubing and put a funnel and filled it off to the side, above fill hole level. Of course, I overfilled it and spilled some on the ground. Doh!
I also drained the front differential. The magnetic drain bolt had a TON of residue. IDK if this had ever been replaced TBH. Refilling that was also the same way with the tubing and funnel, but much easier because you can route the tubing through the front wheel and keep an eye of the fill hole. I had a drain pan under it, which I should have done when I was filling the TC...
I also put fresh ATF Dex VI. Shifted through the transmission gears and the TC gears. Everything seems good. :)
strutaeng
strutaeng
Dallas, Texas
I was finally able to apply 2k sealer to the roof since the weather warmed up a bit. It's kinda of beating trying to reach the middle with a gun full of paint leaning over a ladder. We have some chances of rain tomorrow... we'll see...
strutaeng
strutaeng
Dallas, Texas
I was able to do the basecoat yesterday. It had rained overnight but later we got sun and it warmed up. But then the wind picked up, LoL. And my trees were dropping leaves. I was kinda pissed TBH.
Anyways the base turned out ok. I had some "tiger stripes" after the second coat, but I did a third "drop coat" with reduced pressure and farther gun distance and everything evened out nicely. I think I'm going to deflate the tires because reaching the middle on a ladder is hard when I do the clearcoat.
I also got myself a nicer gun, but I haven't used it yet. It's a Lumma III (rebranded Meiji Finer Core). Most pros. that do YT videos have good reviews on it and it was on sale. I figured I'm saving some money doing this job and at this point might as well invest in it.
strutaeng
strutaeng
Dallas, Texas
I applied the clearcoat. Deflating the tires made a HUGE difference. Then the dark clouds started to roll in. I had to unmask the plastic in a hurry, reinflate the tires and moved it to our front carport... literally just minutes before the rain started falling.
I also cleared my Silverado taillights and headlights since I had a bit of clear left over.
strutaeng
strutaeng
Dallas, Texas
This looks great!!!!
Thank you! I was really second guessing myself there after the sanding and sanding... But it was worth it!
In other less exciting news, my driver's side rear door window started dropping several weeks ago. I bought the window regulator assembly and when I popped the door panel, there was this piece of plywood screwed in there! LMAO
I'm guessing the previous owner did this as some sort of "temporary" fix. SMH. Anyways, I replaced the regulator assembly and window works again :)
Bigburb3500
I'm other less exciting news, my driver's side rear door window started dropping several weeks ago. I bought the window regulator assembly and when I popped the door panel, there was this piece of plywood screwed in there! LMAO
I had an 01 2500 Burb a while back and had bought it dirt cheap. Had tons of issues but the more rugged fix I did was for the defrosters. It was an LT with all the options (except Quadrasteer) but at some point a PO ripped out the servo that moved the blend door. To remedy this, I tied a piece of wire and fed it thru the dash… pull for defroster’s and push for vents
Old school!
BadDaddy2003
