I have questions on this subject, on my '07 Escalade [6.2].My girl's 2002 TrailBlazer story for today:
My girl was on her way to Wa. this morning and got about 30 minutes away and experienced the CEL flashed 3 times and then stayed out and could hear a very dull pop top noise in engine compartment. She called and headed home. Off she goes in her 1990 K2500 ext cab pickup with 130k miles.
The TB has 75k miles on it. I checked for code(s) and got P0300. I drove it and experienced no problems. Plugs only about 3k miles old and I removed them and they looked like new and so did the OE ignition coils and boots-that were done when I did the plugs. Before that I tapped in at the fuel filter and found good fuel pressure at 54 psi running and throttling. When I had done the plugs, I had replaced the fuel filter and did replace the fuel pressure regulator when I noticed a leak.
Ok, I know I have a problem that is effecting more than one cylinder. I did some research and found that a known weak spot is the VVT solenoid. My shop owner friend allows me to buy parts on his account at a local wholesale warehouse. I wanted a Genuine GM solenoid, 12615873, but was not available. I bought a Standard Motor Parts VVT102 for just under $38 and over the years I have had decent results with Standard. Unbolted the P/S pump and flopped out of the way and changed the solenoid. Reassembled all components and it fired right up. I had already cleared the P0300 code. I went to live info on my scanner and all looked good and drove it slow in neighborhood, 35-40 on major side streets and at 60-65 on the highway and romped on it hard a couple times and am still impressed with that 4.2 engine power. No code(s) came back and will be driving it more while my girl is gone for a couple days.
Almost forgot. I plan on cleaning the MAF sensor tomorrow and inspecting the MAP sensor.
So, knowing all this and what I did, what are thoughts of the members here? Thanks in advance for input.
Always best to start a thread. More people see and more replies.I have questions on this subject, on my '07 Escalade [6.2].
Do you mind? And, if not, should I ask here or start a thread?
joe
I think you might need to do a crankshaft correlation relearn, but am not quite sure on the 4.2. Mooseman over on the other board would be the person to ask.My girl's 2002 TrailBlazer story for today:
No relearn needed. I answered in the other forum.I think you might need to do a crankshaft correlation relearn, but am not quite sure on the 4.2. Mooseman over on the other board would be the person to ask.
That's supposed to be taboo around here. Factory design is ok, anything else is pffft.What a fuel pump that you don't have to drop the tank to get to.
Found the fuel leak. One of the plastic stems, on top of fuel pump, under the rear seat, is cracked and spewing. The two lines that feed down under the tank to the fuel filter, are also seeping at the crimp fittings. Fuel filter looks original. You can see the bubbles it is making, in the second pic.
Filthy under that seat and the boy, about 22 years old, is a slob. Stuff all over the seats and floors. I do charge for that too.I am assuming that why these pump mounts are recessed like that into a sump type of area is for protection from impact and / or clearance in fuel tank mounting. But the end result always seems to be that it acts as a trap for water, dirt and debris. Then the inevitable corrosion and failure. That area needs to be able to drain out IMHO. Look at that pool of fuel and dirt.
Young girl down the street said that her 1999 Nissan Sentra will not crank over. This is what I found:
