Escalade pulls to the left - Replaced almost everything!
Jimxms
My new to me 07 Escalade wants to pull to the left. If I let go of the steering wheel, the wheel will turn left on its own about 20degrees. If I hold the wheel straight, the truck drives straight.
I've replaced:
Upper control arms
Shocks & Springs (they needed doing anyway)
Tie rod Ends
Sway bar Bushings.
New wheels (bought some new OEM wheels as the ones it came with were ugly)
New tyres
I had the car professionally aligned to spec on a Hunter 4 wheel machine and got everything 'in the green'. However it still pulls left.
What else could it be?
mikez71
Only thing not replaced is the lower control arms? Maybe bad balljoints or buggered bushings in the lower arm?
Since you did the uppers, I'm guessing the lowers looked fine...
Maybe try a different alignment shop.. ?
J
Jimxms
Post a pic of the alignment before and after printout.
Wil do, it’s going back to the alignment shop today so they can keep it all day and take it on multiple test drives.
One concern I have is that because this truck is new to me and the steering wheel looks immaculate, could someone have replaced the steering wheel at some point. Installed it a spline off and then had it aligned to try and compensate for that?
I was going to plug in my obd scanner to see if there is steering angle reading. If the wheel is installed wrong this should highlight it I think?
mikez71
Funny, I was going to joke that your clockspring is wound too tight, pulling on your steering wheel :p
(clockspring referring to the spiral wiring behind the steering wheel in case you hadn't heard the term before)
Which would mean your steering wheel being installed 360 degrees off..
If the steering ANGLE is off, apparently it's not enough to activate the traction control.. (traction control lights aren't blinking right?)
Scanner won't tell you if the steering WHEEL is off, only the steering ANGLE, which is a sensor around the steering shaft.
J
Jimxms
Which would mean your steering WHEEL being installed 360 degrees off.. (or 720?)
I don't imagine steering angle being the cause.. but lots I don't know. Definately worth checking steering angle.
Haha yeah that would have to be wound pretty tight.
No TC lights on dash or any codes, so if it is off, it can’t be by much.
I’ll report back soon
J
Jimxms
GMT800 2005 Tahoe Z71
Navy Supporting Member
IMO, too much caster lead on the right side. You want a small caster lead on the right for road crown but, again IMO, the 2 degrees more on the right side is too much.
Also, are you saying you replaced all the components to attempt to fix the pull and then had it aligned with this alignment outcome and still had a pull to left or you had it aligned, for whatever reason, and then when pulling left you replaced the components? Then had aligned again? There would be two alignment printouts.
Plus, if it is such a noticeable pull to left, why did the alignment tech not notice it when on an after alignment road test?
mikez71
Agree on the caster, the specs call for 1 degree difference in caster, but the allowable range is +/- 1 degree....?
Rear passenger wheel takes a lot more effort to turn that drivers side. Could this be causing it?
You would think it should be the opposite side..
Does it feel like the brakes are making it hard to turn? Or the diff?
Yea, allowable is for lazy alignment techs. That setting is at the far outer range of allowable and the tech should have road tested and felt the pull/drift and corrected.
Pressureangle
1. Yes, a rear wheel dragging can cause a pull, especially if the rotor heats up from a sticking caliper.
2. Camber creates a pull, as it turns the tire effectively into a cone, pulling towards the small end. Typically vehicles have camber set to pull left to account for road crown. Yours seems like a lot.
3. Caster has a little less effect on pull, a lot on straight-line stability. I never offset caster on my own vehicles. Yours seems like *a lot*. I haven't done alignments for 20 years, so not a lot of experience with independent suspensions, especially 4x4. Caster causes drive steer on front axles, not desirable. If I lived in 4x4 I might care, but I don't so I tend to have mine set at 2x4 specs for on-road drivability.
J
Jimxms
I should probably mention that I'm in the UK so drive on the left and probably caster settings will need to be reversed?
So...full story... I purchased the car and from day 1 it pulled left. I assumed it was just alignment so I took it to get aligned. When they got it up on the ramps everything was rusted solid so they couldnt do anything. I took the car home and replaced everything listed in the original post myself. Then I took it back to get aligned with the new parts installed.
First alignment printout was obviously waaay off because i'd just eyeballed everything.
They dialled everything in to what their computer said and took it for a test drive (I watched this, but didnt get a printout).
It was pulling left, but as it was the end of the day I had to bring it back the next day.
Next day I got the car to them at 9:30 and by 11:30am they called to said it was fixed.
I got there and they then said: " we took it out for a drive, but while parking something went clunk in the suspension so it might not be aligned again."
So basically, yes I know the shop is sh*t and I need to take it somewhere else, but my main concern is that its always pulled left. No matter what suspension parts, tyres, wheels etc I put on it, it always wants to go left. Has me concerned that its something more than just a bit of alignment
J
Jimxms
What I'm not sure of is if a rear right wheel will cause a pull left? I would normally assume it would pull right, but then with 4wd diffs and the like I wouldnt know if it could somehow have a reverse effect.
What I'd like to do is remove the caliper from the wheel and take it for a test drive, but i'm unsure how to do this safely.
Pressureangle
You can't do it safely. The closest you can get is to remove the wheels, pry the pads away from the rotor (both pads) and go around the block without applying the brakes... unless you're in the country, not likely.
Pressureangle
ok, that changes everything; if the vehicle was delivered in a right-drive country, the alignment specs make sense. Driving left, makes no sense. Which side is your steering wheel on? If on the 'American' side, the alignment looks like it would drag you into the ditch. Ask your alignment guy if there are L-R alignment specs, if not take the R drive specs and mirror them for L.
J
Jimxms
It was a US export so steering wheel is still on the left.
I didn’t trust the specs he was pulling up for the car so I gave him this:
Told him to swap the L/R caster settings and use the 4WD toe.
ScottS-Michigan
