So I removed the BOSE door speaker and tested with a 9v battery and seems to react fine. I also tested the impedance and noticed it to be 2 ohms. I tested the wire with a volt meter and got .02 amps and essentially no voltage reading....(maybe didn't do it right).
Anyway. The tweeter on the drivers side appears to be working. So I thought it might be the driver, but now I am thinking somehow it might be the crossover. Is there a crossover per side or did BOSE bury it in the amp?
Just install a new deck, and maybe I have a bad interface module RadioPro 5 or the deck itself Pioneer AVH-x3600bhs.
btw, after testing the radio the 1st time and noticed the driver's sider door driver wasn't working, I removed the radio and tested the continuity of the soldered wires of the left front speaker wires. Everything was good.
Again, is there a crossover in the dash that could of gone bad? There appears to be nothing in the door but the speaker.
Thanks All!
---------- Post added at 09:02 PM ---------- Previous post was at 09:01 PM ----------
oh, one other thing, the contacts on the speaker and wires appear to be clean, even then so, I cleaned them again with a small brush and wire contact cleaner.
Thanks All!
Thanks All!
