What is this plate on my oil pan???
Charlie207
LFOD, New Hampshire
Aluminum is non magnetic. It you live in a cold climate and want to connect a magnetic pan oil warmer then I assume the plate would serve just that purpose.
Can this location easily be reached on a 4x4 model? Others have said it's right above the front diff.
paulwaul1369
I am curious what this plate is on the oil pan of my 5.3L 2008 Suburban LTZ 2WD.
At first I thought it was some kind of inspection plate but from looking at pics of the inside of the oil pan it doesn't appear to have a hole behind it.
So is it some kind of "skid plate" or is it some kind of reinforcement for the cast aluminum pan? Or???
Just kinda curious if anyone knows.
I'm about to find out. I'm changing the oil pump right now. I'm curious to see if it's a quick access to the oil pickup line that bolts to the oil pump. If its not a quick access i guess ill just continue to pull the pan since i already drained the oil. I'll send pics and updates on my findings.
Geotrash
Dave
Richmond, VA
Nope, not a quick access.
kbuskill
kbuskill
NE. FL.
As mentioned above, unfortunately, not a quick access. Pan is solid on the inside.
donjetman
No access, I've had my pan off twice.
It may be for an optional oil pan heater/heating element???
Here's what the inside looks like:
St. Louis
Maybe it had something to do with securing engine when shipping/transporting from the engine plant to the truck plant.
Or maybe when installing the engine to the frame.
Could just be some type of harmonic dampener to stop a NVH (noise/vibration/harshness) when the engine reaches a certain rpm or something
Would be interesting to know
tom3
Might have something to do with the vane type oil pump up front? That could get a bit noisy at certain loads and rpm. Certain engine setups might need it?
paulwaul1369
Ase
paulwaul1369
So I took it off and there's nothing but the bottom of the pan. I was hoping for a quick access to the oil pump pickup line bolt but I guess it must be some kind of pointless scrape plate. However.. after dropping the oil pan I found some tings that should have not been there. Check out the pics and see for yourself. Not sure what they came from... any ideas?
paulwaul1369
Yup. It was what I read on some of the other replies. Just a plate... a scrape plate. Nothing on the other side but the oil pan.
BadDaddy2003
