Shop Started DOD delete
Marky Dissod
Shop got started on DOD delete with a Truck Norris NSR stage 1 cam.
Engine is out. Gonna put a good torque converter in in hopes of saving the trans from trouble.
ecm tune should handle Engine Half@$$ delete.
tcm tune should account for 'good torque converter' and delay transmission problems,
provided you've been maintaining the ATF more often than GM suggested.
B
blondie70
ECM tune ? I already had the ECM set to disable DOD....shop talking about a tune later to disable VVT ?? I think....is that what U talking about Marky ?
j91z28d1
Engine is out. Gonna put a good torque converter in in hopes of saving the trans from trouble. New starter, water pump, oil pump , motor mounts etc......
hopefully all goes well. pulling the engine feels like the quickest way to do it.
Marky Dissod
... shop talking about a tune later to disable VVT? I think ... is that what U talking about Marky?
Ask Truck Norris (or whomever) whether or not that cam works better with VVT enabled, limited, or disabled.
If I was redundant about tuning the Ecm, hopefully I was not about tuning the Tcm (transmission control module)?
A thorough tcm tune
reduces Torque Converter Clutch slip (regardless of what hardware you bought) which helps the TCC last much longer
customizes BOTH shift tables ('Normal' & Tow / Haul) to suit your tastes while protecting the engine and transmission
can enable protocols that may protect the transmission from overheating, or delay or mitigate the damage
B
blondie70
The cam is a non VVT cam. A 3 bolt cam and Summit did not send a cam plate?? or the 3 bolts or a timing chain or the right cover. I was depending on them to sell me the rite stuff. Shop mechanic sez it will need a tune to shut off the VVT electronics. Maybe a little tune to run better with the cam. I gotta talk to him about the trans tune.
I may be off on some of the above 'cuz I don't know what the hell I'm talking about...ha ha ha
Thanks...all advice appreciated. ps...I just ordered a cable to adapt the VVT cable to just a cam cable.
Anyways...mechanic says engine looks really good and they gonna take a hard look at the heads...change the seals regardless.....may take 'em to nearby city to the head shop...ha
Noggles
Which kit did you get from Summit? For some reason there are many different kinds of DOD/VVT delete kits and from what I've found most don't include all the "while you're in there" items so quite a bit of research is needed to do it "right". Did you get a new timing chain cover? That is required for a VVT delete as well as a small harness adapter for the cam sensor that is on that cover. Also what is the cable you are talking about?
As for a tune, I am not sure how different people do the DOD delete but its likely a full custom tune is going to be required anyway because of the truck Norris cam and a good tuner should be tuning the transmission at the same time as its technically the same file that gets flashed (or installed) into your factory ECU/TCU.
B
blondie70
I didn't get a kit. We pieced stuff together (me and Summit guy)..but stuff was left out. timing cover, etc.....and cable I'm mentioning is the adapt cable from harness to cam sensor.
Then I had to order stuff from BTR to finish up parts needed.
Was told a tune was not required for the NSR stage 1 cam I got....but would be better to run one.
Don't know about trans tune yet, but mechanic sez he gonna get tune guy to tune engine....already told him I want trans tune also.
We will see what transpires.
B
blondie70
The job is finished. Truck runs great but idles like a John Deere tractor.
Got all the slip taken out of the trans also..(supposedly). I like the way it shifts now.
When I scan for any codes....I have a fault (hard fault I guess) P0010...CAMSHAFT ACTUATOR.
Not showing as a MIL or check engine light.
Mechanic is gonna get with tuner...someting wong. This ain't supposed to happen (he sez) Anyway, that's where we are not with it.
What U all think?
Thanks, Pete
randeez
south florida
What U all think?
Thanks, Pete
...whatd you do with the actuator?
nothing?
limiting block installed?
delete and install 3 bolt gear?
just read the post before... if you deleted dod its going to need at the very minimum dod turned off and DTCs turned off
it may not need a tune to run ok with the cam specs, but the ecm is still going to try and go into dod mode
Marky Dissod
Looks like the VVT disablement is a bit more complicated; the CamShaft Actuator DT code must ALSO be disabled.
There may be other less obvious steps.
B
blondie70
nothing?
VVT deleted. 3 bolt gear in.
DOD is off.
Engine tuned for cam.
Trans tuned....all slip out (did not talk to tuner)...mechanic took it to him. Tuner is hard to get ahold of....hiding or something....but is supposed to be good. But maybe not so good ? I didn't know a tuner around here. He is the only game in town, evidently.
randeez
south florida
DOD is off.
sounds like vvt also needs to be disabled and codes turned off
do you have hptuners?
B
blondie70
No. The super duper tuner in town was supposed to handle all this. So say, he is the one who tunes all the Vettes and Camaros in town. Wonder why he couldn't do this right ?
randeez
south florida
so 3 bolt cam/gear, did you use the correct timing cover also?
i dont think sensor on the vvt actuator cover will pick up the reluctor of a 3bolt cam gear
B
blondie70
Yup....correct timing cover. I talked to the tuner today. He sez the hard fault I see with my scanner is nothing to worry about...in fact , it may go away on it's own soon....There is no MIL on the dash. He did a number of thing with the tune...to engine and trans. I am ok with his summary of what was done. Seems to know his stuff. Sure had a bunch of fancy rides in his shop that they were working on.
1948Buickroadie
