1999 Tahoe, soft brake pedal
99brokeTahoe
My apologies if this problem has been addressed in another thread, I could find some close, but not the same. 1999 Tahoe, original problem was brake pedal would intermittently feel "notchy", like the ABS was actuating, but I know what that feels like, and this isn't it. Truck has 290,*** miles, and I have replaced a lot parts, but not a brake MC. Replaced MC with a NAPA MC, bled all 4 corners till the fluid looked good coming out, did the "dirt road ABS bleed procedure". Brake pedal felt better than it ever had, but problem with pedal feeling like it was binding, or hanging up, would still happen intermittently. So I replaced the booster with a NAPA booster. To me, brakes feel worse than they ever have. I'm not an engineer, but it's like the return spring in the booster is too strong, so you can't make the pedal move as fast down, but it has enough assist to go to the floor. Truck has almost everything new in the last year or 2, and the aftermarket booster has made the pedal feel soft to me. Truck will lock the wheels, and make the ABS work, but you can't do it as fast now, than you could have with the original booster. Guess I need to try a different brand booster? Any suggestions?
Matahoe
Military
Grand Rapids, Michigan
Binding, chattering or resistance when pressing the brake pedal would either be the linkage from the pedal to the MC or the MC itself. The vacuum booster is easy to rule out. Just disconnect and block off the hose at the booster and see if pedal travel feels any better, worse or same when taken for a drive. Just be aware you will need a heavy foot and increased distance between you and any object in front. Gonna take longer to stop. Brake pedal travel should feel the same with or without booster. This should get you pointed in the right direction. There is a recall TSB related to the brake rod retainer but not sure if that involves how the brake pedal feels.
rockola1971
Indiana (formerly IL)
Did you get the little rod that goes into the brake booster out of the old one and install into your new one? Is your brake light coming on? I suspect you still have some air trapped at your ABS manifold because you didnt use an auto bleed feature of a bidirectional scanner. Seen this scenario right her on this forum so many times.
99brokeTahoe
I have a Chinese Tech2, and I'll try service bled procedure. I have always had good experience with just making the ABS work on loose gravel road. Before I installed the new booster, I looked at both side by side, expecting an adjustable push rod, but didn't see that, and I didn't notice anything different between the 2. If there was a rid extension on the old booster, I didn't notice it. Brake pedal felt good till I changed the booster. I didn't open the hydraulic side of the system to change the booster. I think I just got a bad/wrong booster, or maybe I missed an extension rod on the end of the old booster. I have a 1997 Tahoe parts truck that I'm going to try and swap boosters with. It just seems like a lot of work for a used part, and maybe my expectations were to high for my NAPA part. Before I do anything, I will try the bleed procedure with my scan tool. Frustrated, and was hoping to find a "magic silver bullet", so to speak here. I've had a few of these trucks before, and worked on a lot more, and never had this much trouble.
99brokeTahoe
Also, new member. Just joined. Haven't been on any forums in a while, but used to read them just to learn. The tech threads on here seem to be a lot more "right" than the Facebook groups. Anyway, seems like a lot of good knowledge on this forum.
99brokeTahoe
rockola1971
Theres a very good collection of good guys on here with everything from super freaks who stick 6.0's with goodies mounted on the engine in place of their tired 5.3L, transmission rebuilders (for a living) to guys that have owned or do own repair shops. Its all here and everything in between. I also have the clone Tech II. I always use the bleed feature on it. Its never done me wrong.
Matahoe
Military
You can do that but either way you will need to bleed the lines again after driving. Maybe 2 or 3 times. The automated bleed just lets you do it in the shop so you're not having to drive then bleed repeatedly.
Eman85
Best fix I found on OBS trucks is to use a NBS MC, makes the pedal feel like you're actually going to stop. I must just be lucky but I've never had any problem bleeding these brake systems and I do have a scan tool that can do the ABS activation but never see any difference if I do it that way or without.
Test on a booster is to pump the pedal multiple times with the truck off. Then while holding pressure on the pedal start the truck and you will feel if the booster is working as the pedal will drop.
The simple test on a MC is buy 2 plugs for the MC, thread them in and step on the pedal. This will let you know if you have air in the MC or just how high the pedal can be if the system is good. Of course every wheel's brakes should be inspected and all of the lines especially on a 25yo truck.
99brokeTahoe
I've never had a problem bleeding brakes like this before, unless there was failure in the system, and I had hard time getting the portioning valve centered. Everything is new within the last year or two as far as the brakes go. I did try my Tech2 to do the automated bled procedure. It wouldn't because it had speed sensor codes. I cleared the codes, then it worked. I did some research on the codes, and found a TSB on the speed sensors, that sounded like the problem I was originally trying to fix. After reading this TSB, I think it was the ABS trying to activate, but not like it does at speed in loose gravel. About a month ago, I replaced both CV axles and wheel bearings. Both axles, bearings, and bearing hub bolts were difficult to remove. Rust and age I guess. I even replaced the hub bearing bolts with new, and coated everything with antiseize. The TSB talked about dirty wheel speed sensors, and rust on the mounting surface causing the low speed ABS problem. Last night I pulled the front wheels, rotors, and calipers to check the sensors. Both sensors, and the reluctor wheel teeth had antisieze on them. I think that this is what caused my original problem. I cleaned everything, put it back together, did the automated bled again. The pedal doesn't feel any different, and I plan on bleeding all 4 corners today again. What kind of plugs would you use in the master cylinder? Maybe I'm overcomplicating it, but I thought that they were an odd straight metric thread with an odd bubble flare, is the reason I ask. Thanks for all the replies.
Eman85
There is no such thing as an odd strange thread, it's all measurable and once you know the size you just buy a plug that size, I don't even think they are metric. I can't remember the size but if you look up MC specs it should give them to you.
I've had problems with ABS activation after hub replacement, mostly from replacement hubs with too much play or runout, ABS will see different speeds between the 2 front wheels usually just before stopped and it's hard to see on a scan tool. Cleaning the surface where the ABS sensor mounts is important. Also be sure to use a torque wrench tightening the axle nuts, not an impact.
Here's a link to everything you wanted to know about fitting size and MC's.
99brokeTahoe
I understand. They just don't look like regular hardware store flare fittings, and I didn't know what I could use that wouldn't damage the sealing surface.
99brokeTahoe
Old and new push rod, side by side. Looking back, I think I caused the original problem when I replaced both front hub bearings, and contaminated the sensors and tone rings with antisieze. I thought it was something binding in the linkage, MC, or booster, but it was just ABS coming on a slow speeds. I think the problem is in the ABS module now, but I'm going to try and bled it again. Thanks for the reply.
99brokeTahoe
I did automated bled process with a Tech2 scan tool, then manually bled all 4 corners after, 3 times. No change in how the pedal feels. Just to be clear, the pedal is firm with the engine off, and doesn't "pump up". When running, it will go to the floor, but will lock the front wheels before it ever gets to the floor. Just to note, doing the automated bled process would actually push the pedal back up off the floor. I'm going to try a used ABS module/manifold today when I get home. There is no brake light on, and there no codes either. Truck has 290,*** miles, and I believe I created this problem with the contaminated speed sensors, and the ABS module is either damaged, or just wore out, and something is bypassing internally. In the past 2 years, I've replaced calipers and lines. Never had a problem bleeding it. I've replaced both wheel cylinders at a different time. Never had a problem bleeding it. Changed both hun bearings because I hadn't done that yet, and because I was replacing a CV axle. Right after that is when I thought my pedal was binding, so I replaced the master cylinder. Didn't have a problem bleeding it then either, and brakes felt better than they ever had. Last thing I did was replace the booster, again because I thought it was binding. I didn't open the hydraulic system to replace the booster, but right after that is when I started getting the low pedal. So, with all that being said, I'm going to replace the ABS module off another truck I have, that is "known good". Again, thank you all for the help.
Eman85
Why not put the old booster back on. Most parts purchased today aren't as good as what is being replaced which is why replacement instead of diagnosis usually puts people further down the well.
If you want a really improved pedal do the NBS swap.
99brokeTahoe
Old booster was turned in for core charge at the local NAPA. I think it was coincidental that my pedal went soft changing the booster. I didn't get a chance to swap the ABS module, but I tried something else. I'm not saying this is fix for every low/soft brake pedal either, but it made a big difference in how my brake pedal feels. I simply unplugged all 4 electrical connectors. I started the truck, and now have both ABS light and BRAKE light on, witch haven't been on at all. This made the biggest difference in pedal feel to me, I would say 75% of what it was before I started having any problems. No, this didn't fix anything, but it did make the brakes feel a lot better, and makes me more hopeful that changing the ABS module will fix my problem. Just a quick recap, I think I had the low speed ABS sensor problem. My brake pedal with the engine running will go to the floor. I've bled it with scan tool, sliding the tires on loose gravel, and bled again. Unplugging the ABS module made the biggest difference in my particular truck as far as brake pedal feel. Yes, both ABS and BRAKE lights came on, and yes you can lock the wheels up at will, but the brake pedal doesn't go to the floor like there's nothing there. I'm going to try and swap the module tomorrow night, and hopefully, that fixes my problem.
east302
Mississippi
Just curious - are you just swapping the module (black part with Kelsey Hayes on it) or the whole thing with the valve assembly and combination valve that the lines go into?
Since it is improved with the module unplugged, do you think the issue is with the controls rather than something mechanical in the valve portion?
V8Soulja423
