solli5pack
- Joined
- Jun 17, 2023
- Posts
- 499
- Reaction score
- 769
Hey everyone. So I've been dealing with flickering lights for the past few months on my 08 Yukon and so far haven't been able to figure them out. All the exterior and interior lights flicker and I believe the dash lights flicker also so pretty much the entire truck. I replaced all the battery cables with GM parts, replaced the alternator twice with the one of Amazon that @Geotrash recommends often and tested all the grounds in the engine bay for voltage drop and all tested good. I even pulled the front bumper to inspect and clean the ground locations on the support. So far nothing has worked and I'm stumped. The battery came with the truck when I bought it a year and a half ago so unsure of the age but the battery only starts the truck right? So how could it cause flickering? I have the Suburban so I guess I could start swapping some stuff like headligh switch or relays to see if it helps but I'd rather not. No voltage drops at all when the trucks running. Also the flickering seems to be directly related to when the engine RPM's increase wether driving or parked. I did find corrosion in almost everything I replaced. I think this truck spent a lot of time at the Jersey shore with its previous owners.See below. So many times I thought I solved it. Any ideas?
