Belltech Anti Sway Bars
djensen9367
Just added Belltech Anti sway bars, front and rear. What a difference-no change in ride quality but handling and corners are a great improvement. Always have liked Helwig but they don't make a front sway bar for my Suburban and Belltech had a matched set front and rear. Only set to OEM+ as I do not tow anymore. If you are thinking about doing this I highly recommend as there is a noticeable difference in performance
Thank you for posting the results of your evaluation of your Belltech sway bars. Did you 'test' them out on a cloverleaf or equivalent test road location to quantify the amount performance improvement?
djensen9367
djensen9367
i have some good curvy mountain roads to play on that i use often. main highways and cloverleafs do not offer much of a challenge compared to narrow curvy roads. Big improvement over stock for sure
veteran111
