Sooooooo, I bought a PPV ...
RichardCranium
RichardCranium
Mebane, North Carolina
MAS
RichardCranium
RichardCranium
Nice rollers!
What camera gear?
I've only attempted rollers once and got some decent results.
A buddy did the rollers for me, I shoot antiquated DSLR stuff (with mirror)......I'm a Canon guy. For all my still shots, I am using a 1D Mark IV and primarily a Canon 100-400 L lens. For these rollers, Mike is a mirrorless Sony guy, I think......I'd have to check.
pwtr02ss
Tennessee
I switched to Sony last year, from Nikon. Totally worth it. The image stabilization is crazy good. I have both the a7r4 and the a7r5. I don't wanna clog your thread with my junk.
Excellent job, both stills and the rollers
vsp4717
Richmond, VA
Interesting!
I did not know that, have a part number by chance? I'll try to look it up later if not, no worries.
It will depend on the original wiring on your Hoe. I have a 2014 and I looked into this. Requires a 2015 or newer wiring harness to be plug & play. But don't give up - I found a very nice alternative that uses the current wires and has TWO USB connections. It went in one of the 12v sockets and looks factory when you are done. You will have to enlarge the opening a very small amount, but the entire install was 15 minutes. Here's a link to it:
Rydonair Aluminum 4.2A Dual USB... https://www.amazon.com/dp/B07CJW3ZRP?ref=ppx_pop_mob_ap_share
RichardCranium
RichardCranium
Good stuff. Do you have a picture of it installed, the finished product? I'd like to see it, I definitely would do if it looked pretty close to factory.
RichardCranium
RichardCranium
I went ahead and picked up the USB adapter that @vsp4717 mentioned, got it installed today. If y'all have read this thread so far, you know I like to photo document. Mainly so anyone else with less experience can see what it would take to do some of these things. This was pretty simple, honestly the hardest part of this was getting the faceplate trim out from around the radio (always fear scratching or cracking it). But it just takes some patience and a few pry tools to pop each fastener.
My setup prior to today: left was/is a traditional cigarette lighter socket, the right side was a USB into for AndroidAuto. That USB socket used to run directly into the back of my Alpine iLX-650 for that easy access to plug my phone in. Why Alpine put the socket on the back? Who TF knows. But I installed a Moto AndroidAuto wireless dongle in there and haven't looked back. Wireless AndroidAuto FTW.
Gathered the tools I'd need to pop off the faceplate trim.
Faceplate off, HVAC and lower insert removed.
Located the power plug I removed from the passenger side cigarette lighter socket (where I installed the USB for the head unit).
Since it wasn't plug and play, it was a simple snip of the power/ground and some male spade connectors crimped in place. Plugged it in, KOEO, works great.
RichardCranium
RichardCranium
@vsp4717 was right, not much room was needed to get this socket to fit. In fact, if the factory faceplate was thinner, this USB hub would actually thread in. The barrel of the hub fits perfectly into the opening, here is the "just the tip" teaser.
So, I had to come up with a way to gain more clearance and make sure to keep the socket opening 'round'. I found an 18mm socket would work great.
I had some sandpaper with velcro backing, for a sanding block. I grabbed some 80grit and wrapped the socket went to work. Normally I don't wrap it.....doesn't feel natural.
Here it is after I pulled out. Awwwww yeah......grab a rag.
The socket came with a locking right you can thread on, but with the center pocket in that lower trim panel, there is no way it would fit on all the way. If you could get it on, it would certainly be crooked. And this USB socket won't sit "flat" on the face, unless you clearanced a little of the shoulder of the face itself. I didn't mind the ~2mm gap, since the rubber grommet/cover for the USB outlets sort of filled it.
So I test fit the socket, and determined I could sand off 2 of the knuckles on the retainer ring. I could still thread the ring on, but would have the sanded side butt against the center pocket. This would also give me a place to super glue the retaining ring to that center pocket.
992dr
Eastern N.C.
Man, I can tell yah one thing, I sure do appreciate your photo documenting everything. Anything with wires makes me weary haha. That is coming from an electronically challenged induvial :)
I appreciate all of your posts
RichardCranium
RichardCranium
There comes a time for all of us.
Unfortunately, that time has come for me.
Time for a trickle charger, that is. :lol:
The Diehard is dying hard, but figured mostly from my not needing to daily the Tahoe in about 3ish years now. Pretty thankful to have a take-home vehicle for work, and thus the battery life is diminishing. The funny part is I already had this charger for the Z06, thinking of need it since it's a fair weather car. Nope, that Optima hasnt flinched.
Trickle away....
a1parrothead
