LowCountryTim's 2011 Tahoe Build Thread
LowCountryTim
LowCountryTim
South Carolina
You can get complete replacement upper and lower control arms with new bushings and ball joints that will make the swap a lot easier for the diy guy with them being that cracked up I’d lean towards replacement
Last time I looked I think the lower arms were maybe 150$ a piece give or take
The uppers I’m not sure cause I ran aftermarket upper control arms
Thanks, I just really wasn't sure if they looked good or bad.
I was leaning toward pressing new ones in just to try something new. Ofc it's a lot cheaper too, but I figure if it goes South I could always order new ones.
I want to to the 2" drop spindle so I'll be keeping the stock upper arms.
I think the biggest pain would be replacing the ball joint as I think you need to grind the flange off.. Certainly if I were doing the bushings I'd do everything.
Probably a PITA but I like trying out new things. Plus I got an excuse to buy a press haha
Trey Hardy
The stock uca are a pain to change the ball joints out if their original is still lean toward just getting new arms you’ll thank yourself later for not having to fight it and deal with the headaches or waiting for the parts if something goes south while trying to get the old bushings and ball joints changed out
Trey Hardy
If you got a hydraulic press that would make things a lot easier
But again for buying a press you could use that money to get all new arms at the same price if not cheaper and you would be able to have the job done in a couple hours with the right tools then you’ll just need a alignment.
Check out dirt king fabs locking alignment cam plates also you won’t have to worry about knocking your alignment out with then vs the stock ones that like to come loose over bad bumps
LowCountryTim
LowCountryTim
South Carolina
Looked at the price difference for the lowers.. No sense pressing new bushings in. The ball joint itself is like $80, plus the bushings.. would save like $30 each. Not worth the hassle.
Didn't look at the uppers.
starsplitter
Purchased about a year ago for the right price. 250k on the odometer. Plan is to make some improvements on a budget while teaching my son (who just got his learner's permit) a few things, then letting him use it when he receives his full license.
Tentative list of items:
-replace charcoal canister (slow fill) - COMPLETE
-replace driver side motor mount - COMPLETE [also replaced the passenger side]
-replace dashboard
---get the gauge cluster refurb'd while it's out?
---upgrade factory radio to tesla-style
-replace interior carpet
-replace seat foam driver's seat
-new wheels/tires 285/45r22
-McGaughty's 2" spindle drop
---replace lower control arm bushings (worn)
---replace struts Bilstein 5100
-Belltech rear spring 3" drop
-new front/rear bumper covers
I would highly recommend a new timing chain/oil pump. I bought my Yukon XL at 242k and it ran well. Had one issue with the oil pressure which the sending unit did not correct and a month later the timing chain let go. It was well maintained, but the timing chain didn't care. New motor.
LowCountryTim
LowCountryTim
South Carolina
So this is the cowl and wipers after they were painted.. looks good. I stopped at 2 coats because I wanted to make sure it didn't get too glossy:
I also had to replace one of these because I broke when I took it apart (not due to negligence, they were just old and brittle):
Took a while, but I found replacements at McMaster (although I had to buy 10... the OEM is in the center):
LowCountryTim
LowCountryTim
South Carolina
Did half a thing today.. Pro tip.. order the travel limiting bumpers when you order the oem struts. I couldn't see it before disassembly and it was toast. Ended up having to put the old one back in as nobody had them in stock. So I get to do this one a second time. Deferred doing the other side until I have them.
I don't so much mind the time to do it again, but man messing with those springs and a compressor stresses me out.
LowCountryTim
LowCountryTim
South Carolina
In the words of the illustrious Ted Theodore Logan, "something strange is afoot..."
While driving, noticed the seatbelt indicator was flashing.. only.. I was wearing the seatbelt. Did a quick unbuckle-rebuckle. Still blinking. Meh, figured maybe a loose wire.
Then the speedometer went to zero and the tach rested at 1k. Other gauges/shift indicator working fine. Oh boy.
Got home, turned off, restarted. Same issue.
Checked the fuses. Did find a 15A for the trailer harness blown, but everything else was good.
Restarted. Everything works normally now. Good? I guess?
Any ideas as to what this was? Gremlin in the ECU?
LowCountryTim
LowCountryTim
South Carolina
Removed the strut I did last weekend and installed a new bumper.. And did the remaining strut. Glad it's over with.
Best to just order new bumpers if you're going to tackle this. You can't actually see them until you take it apart.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Love your detailed posts and pics bro. Got a link for those McMaster parts for the washer hose 90*s?
Did you research drop spindles yet? One brand uses a stud and nut for the top wheel bearing bolt and another uses the through bolt.
I also have a slightly used set of 3” rear drop springs if you are interested.they are not name brand they are off eBay but ride good.
LowCountryTim
LowCountryTim
South Carolina
McMaster: http://www.mcmaster.com/5463K177
If you need one I can just drop it in the mail to you. Just message me your info.
Yes, I had researched the drop but with everything else I'm doing I don't think that will get done anytime soon.
Still have to get the replacement dash in, but 2 buttons on the radio aren't working so looks like I have to do the radio upgrade now too.
Wear indicators are showing on the front rotors, so looks like that's coming quickly as well.
I did manage to pick up some nice Michelin takeoffs, so now I need rims.
Tim
LowCountryTim
LowCountryTim
South Carolina
Bringing this thread back from the dead.. the irony isn't lost on me.
After sitting in my garage for a year, I finally got the new dashboard in. took me 75 minutes to get the old one out. Longer to get the new one in, but only because I took the opportunity to do some other work-- namely, update the head unit.
I purchased a Android 13 head unit from aliexpress: https://www.aliexpress.us/item/3256807308225303.html (though i bought it about a month ago and it was twice the price then).
Short answer: yes, it's worth it.
Laundry list of random things that always come up:
  • There is no RAP/IGN wire in the stock harness connected to your factory head unit. That is provided via canbus to the factory head unit.
  • The Android head unit I purchased came with a canbus adapter and the unit was preconfigured for my vehicle
  • My unit came with the appropriate adapter to connect the USB port in the center console
  • Yes, you lose onstar, but it doesn't work anyway due to it being 2G in these vehicles
  • Yes, you lose SiriusXM (which is kinda a bummer, but you can use the SiriusXM app on the android head unit if you purchase a SIM for it or tether to your phone's data). There is no way around losing XM with these units. You can buy a Pioneer or similar "SiriusXM Ready" head unit then buy the SiriusXM tuner if you really want it (of course now you also have to buy the canbus adapter and wiring harnesses that come free with the Chinese unit). You can also buy an external SiriusXM tuner such as the "roady" or "onyx" for like $80. This is probably the route I will eventually go.
  • No, you can't retain the "factory" chimes, per se as that is also done via canbus. My canbus adapter came with an external speaker for the chime sound. It works fine for me. The closest you can get to "factory" chimes is a Maestro RR adapter, which, by the time you buy that adapter and the required cables, will be about $300. Factory chimes are played over the left front speaker.
  • Yes, you can retain the factory microphone if you splice into the harness.
  • This radio does not have an RCA video output for the RSE. If you really want that, you can buy a USB adapter and the head unit does have a setting for USB video out (more on that below)
  • Yes, the unit works with factory Bose and it sounds much better than the factory head unit.
  • Yes, wireless Android Auto works on it (don't have an iPhone to test carplay, but the unit says it supports it)
  • Yes, the specs are correct. Some of these Chinese vendors patch their software to make the unit look like one thing when they actually have less ram/less storage/lower android version. I ran DevCheck and the specs are correct.
Thoughts on the RSE:
  • I spent way too much time trying to figure out how to incorporate the RSE.
  • I finally realized that it is a waste of time to even bother with RSE.
    • The screen is small
    • The screen resolution is poor
    • Infrared headphones? Who wants to bother with that. Everybody has bluetooth earbuds now.
    • DVDs? Really? Yeah, I'll install that player right next to my 8-track. Kids have everything they want on a portable device.
    • Using RCA will always yield garbage video compared to what we are used to.
  • I think a better solution is to replace the existing flip-down screen with a new android flip down screen
    • Everybody is familiar with the interface. They can use the touchscreen to navigate to whatever app (video, music, game) they want
    • They can pair their bluetooth earbuds to the android screen
    • They can mirror the screen from their device to the android screen
    • Control of the screen does not interfere with the main head unit, nor does it require the attention of the driver
    • I assume you could pair the main head unit to the flip down unit for some sort of control if you needed to do so (eg kids in car seats). There's probably many different ways to achieve that goal, but I don't have a need.
Lastly, I've never even used the RSE. Consequently I am not upgrading it now, nor am I spending any time trying to interconnect it with the head unit. I am going to connect the RCA in from the back of the center console to the flip-down in. So somebody could put video on it if they wanted to. Maybe I'll upgrade the screen in the future, but for now I am not going to bother with it.
I added this USB charging port which also has a USB passthru connected to the head unit. I find the USB ports in the console to be a pain for everyday use (I may use it for a USB stick or something). Note that only the USB-A port is passthru to the unit. the USB-C port is charging only. I went with Scosche just because I figured it was less likely to burn my truck up than a chinese version. It appears to be high quality.
I also ran this wiring harness for a future dashcam. It was easy to run while the dash and A-pillar covers were off. I left it tucked into the overhead console. Wiring was extremely easy as I routed it to the radio location. Power and ground was tapped off the cigarette lighter as I had to cut that for the new USB charger anyway. The CANBUS adapter provides RAP power (versus IGN power) which I thought was a better choice for the dashcam. ALso everything is neat and you dont even know it's there versus hacking into the fuse box or whatever.
I am still playing with configurations for the radio, and there's definitely some changes you need to make to get it working properly.. so this post is a work in progress.
LowCountryTim
LowCountryTim
South Carolina
So update on the android head unit. As expected, it's not for the faint of heart. I figured there would be some issues, which is why I got the $250 (now $125) radio instead of the $600 phoenix radio which has the same issues at twice the price.
First issue is a software issue. Their unit does not trigger the amp control wire properly. SUpport gets back to you in 24-48 hours but it's mostly useless (basically, did you try unpluggin and repluggin it?).
I ended up connecting the amp trigger to the antenna control rather than the dedicated amp control wire coming out of the unit. Problem fixed.
Second issue-- and a know issue across 100% of the cheap android radios, it bluetooth microphone volume. To be honest, the mic built in to the unit isn't that bad, so I'm using that for now. The external mic they provide does sound a little better. I spliced in the tahoe mic and it's not as good as their mic. I may purchase a better mic of amazon and splice that into the harness and replace the tahoe mic. BUt for now, i'm happy with the mic built into the unit.
Capybarbro
