Evap issue question 09 yukon 5.3? - SOLVED
GMCYukon2009
I've replaced the canister vent valve solenoid ( by rear end) and the canister purge valve ( on engine ). I still cannot fill fuel without the gas nozzle clicking off often. I can fill slowly.
Can I run the vehicle or will something else go wrong before I can get it fixed?
Thanks
solli5pack
Thanks
Don't forget about the Carbon canister...if it's clogged filling up with gas can be an adventure.
Geotrash
Dave
Richmond, VA
For me that was the culprit on my 2010. When I had the canister off, I pressurized the gas tank with air from a compressor at the filler tube to blow out the lines. The canister was heavy with fuel as a result of to often topping the tank off to overfilling.
Yep. Without people doing that the canister would probably last the life of the vehicle.
91RS
GA
If the canister came apart, you’ve got charcoal everywhere, including the lines in the tank. I had to replace my hard line, which is now discontinued, because I couldn’t get it cleaned out. I managed to get the pipes on the outside of the tank cleaned out by squeezing the whole line with pliers to break up the charcoal and blow it out. I had to drop my tank and I duct taped a smaller piece of nylon pipe to a shop vac and sucked the charcoal out of the line and cleaned up what I could from inside the tank.
Towmaster
