Language on Dash Display
Rallysports
Columbus
Has anyone else had an issue with their dash rolling through all the languages? Mine is just rolling through English, French, and Spanish over and over. I cannot even get to the fuel info or the odometer. Every now and again it will stop but only momentarily and then starts going through them again.
I have already had this dash replaced because of the needles sticking. I am wondering if this is another dash issue or could it be an issue with the steering wheel controls.
Thanks
JK
R
Rallysports
Columbus
Here is a pic.
R
Rallysports
Columbus
Are those the ones on the steering wheel? If so I was thinking that too. I tried pressing them and get no response from any of them except the menu looking button which causes it to show the currently set language. Like when it is cycling through if i hit that button it will jump back to English, but then it keeps cycling. Pressing the arrow button does nothing.
It does it so often now that I can't get to anything else. I have thought about just replacing the steering wheel portion but just don't want to waste funds.
JK
c00kedg00se
JK
Did you ever resolve this issue? I have a 2004 Tahoe z71 with the exact issue going on. It just continues to cycle through the language options and I can not get to any other menu options just as you described.
Andrew
the problem "could" be either the steering wheel buttons or a fault in the cluster, wifes truck had this issue I replaced the buttons and still had the problem, had cluster rebuilt locally and problem went away.
^^This^^
And this is just a wild guess, but these clusters can get what's called "silver migration" on the circuit board. The cluster can be disassembled (like when changing stepper motors or backlighting) and the circuit board cleaned. I'm not saying that's what causes this, but it's a possibility.
WITCH1975
