2001 Chevy Tahoe Wiring Harness
Matthew Jeschke
Sahuarita, Arizona
My harness is starting to have issues. Evap is doing weird things. Also when I'm tuning data I notice the Wideband won't read same as PCM unless I tie the grounds together. I think it maybe time to get a new engine wiring harness. Anybody know a good deal for decent quality? I see them all over eBay and amazon (FYI ~ I boycotted amazon). Not sure if they are Chinese junk though.
tooleyondeck
Northwest FL
OEM harnesses are hard to find new. There are some used ones floating around ebay and you can check your local junkyard. Another option is a standalone harness like a Painless or PSI:
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Yeah I may have to buy a used one and clean it up. My truck has lived it's life in AZ... It has almost 270k miles on it now. I never have completely removed my harness, however, I rewrapped a bunch of it and cleaned it up. All the wire insulators are melted together, and it's really ragged. Some of the connections are starting to fail too. Right now the purge solenoid for the evap has shorted to something else. I've not had time to diagnose it but I suspect it's getting horrible mileage due partly to that. Sometimes I throw O2 heater codes also. I have fiddled with it trying to fix it up a couple times but getting sick of it.
That painless looks like a good route if money was no object. There's tons of new harnesses on eBay but they're all for like Camaro's and Corvettes. Surprised there's none for the trucks.
strutaeng
Dallas, Texas
Understand. Most (if not all) of the connectors can be bought and replaced.
I made this post a few months ago: https://www.tahoeyukonforum.com/thr...-engine-transmission-wiring-harnesses.143808/
I've since removed the engine for a rebuild. I replaced the coolant temperature sender pigtail because the little tab had broken on mine. I'm at 262k on my truck, so similar mileage.
The hardest part of removing the harness is the underneath part, especially feeding the long harness down the transmission through the bellhousing. I did by myself, but a buddy helping will make it a lot easier. 4x4 would also complicate things, I think.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
@strutaeng thanks for the tips! I think a few signals go into the cab for the instrument cluster. Was that a PITA to get those fished out? How did you do those? I'm wondering if a person could just install a connector there to avoid taking the grommet apart.
I called my favorite junkyard. They think they have a harness for me. They're checking... I think I'll swap the new one in and use my old one as a template to possibly build my own harness if I ever find the time. Although I've no clue where to buy all the connectors and different color wire without going broke.
strutaeng
Dallas, Texas
Cool. Hopefully you can source a nice clean harness.
The engine/transmission harness actually does not go into the cab or cluster. There's like 3-4 connectors at the fuseblock for the engine/transmission harness (4x4 models have an extra connector the T-case) and the other main connection is at the ECU. On that thread, I believe I posted a photo of the fuseblock after I removed the engine harness.
At the fuseblock, there's other connectors that I believe go to the cab, and maybe the TAC module on models that have that.
Does your truck have EGR? If so, make sure the donor harness has that. I think somewhere in 01-02 EGR was phased out?
squeeler642
Question for anyone that knows...
Would something like this work? TSP has a memorial Day sale on now, figured I'd take a deal if I could get it. Haha.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
@squeeler642 thanks! I almost snagged a used harness... Ultimately I need to buy a harness like you showed there or just make my own. They're really cheap if you have a F-Body or Corvette. However, the truck ones are quite expensive. I may just buy an F-Body one and change out what I need to for the truck as then I have all the connectors.
Although, I didn't ever see the one from texas speed. That's the best price I've seen yet. Painless I think is another one that has a harness but it's like $600. I have a buddy building up a LM7 w/ big blower and put it in his 1970's truck. They're doing a custom harness for that but he's using an aftermarket controller... I think the Holly one.
squeeler642
Your buddy's truck sounds sick. Haha. And it sounds like we are both having the same problem. I'm on the hunt for a new harness because my daily (03 Tahoe, swapped the 5.3L for a baby-cam 6.0L last year) is having some weird sensor issues... Looked into it and found the engine harness wearing on the steering shaft/column between the header and the frame rail. Given it's my daily... I don't want to deal with buying a used harness to save a buck, only to wind up having to troubleshoot/repair after installing it. Would rather spend a little more and make it a one and done experience.
Only issue I can find is that the TSP harness has EV1 style injector connectors... And mine are EV6. So I'm really going to be in it for the harness plus injectors. But the TSP harness is almost half as expensive as the alternatives, and my injectors are OEM as far as I know, so maybe it's a good time to remove/replace to make the new harness work. I'd like to size up on the replacement injectors as I have dreams of throwing a blower on this truck one day (like your buddy) and would like to have some headroom in the fuel system for that.
To that end... Does anyone know if I'll have to adjust my tune for a bigger injector? Is that something the fuel trims will just work out on their own or will I have to go in and actually change some of those tables? I would assume that's a big enough difference that my tune will have to be adjusted.
justinakay79
