My current fuel trims - idle, 2000rpm, 3000rpm all no load
2006Tahoe2WD
Silicon Valley
Here are three graphs of my current no load fuel trims, idle, 2000rpm, 3000rpm.
Why does the LTFT go up to 15-16% just because the rpm went up? The graphs span about 45 seconds.
I don't have any codes showing up but I don't like this.
Idle
2000 rpm
3000 rpm
LTFTs are learned over time over various RPMs and engine loads. Your STFTs look fine, but compare them under load (maybe carefully power braking). Adding LT & ST trims (by banks) together, they should be within ±10% so they are a bit high now.
If you've had any trouble in the recent past that's been corrected (vacuum leak, MAF cleaned or replaced, O2 sensors changed, spark plugs, air filter, etc.) then I'd suggest resetting the LTFTs with a scanner, and monitoring them going forward. Even if no problems like that have been fixed, it might be a good idea to reset them anyway, and monitor to see if they come back high over time. (The STFTs will be reset at each ignition cycle.)
It wouldn't hurt to see if the computer sees more alcohol than you're actually running; what do you run: ethanol-free, E10, E15, or some version of E85? If not high alcohol-content fuel, but the computer thinks there is more alcohol than there actually is, then it will be adding fuel. But that situation usually shows up in the STFTs. If you've run E85 or a high alcohol content fuel in the recent past, reset those LTFTs and monitor.
I'm curious as to how much they change over time.
2006Tahoe2WD
Silicon Valley
Recent: cleaned MAF, 4 new OEM O2 sensors, new purge valve.
The motor is not flex fuel. I think the fuel I buy is 10% alcohol.
My Foxwell scanner has an issue (corrupted memory) and is a brick at this point. The "fix" /reset process isn't working for me. When it was working the new O2 sensors were working great.
I read that if the battery is disconnected for ? 1 hour it will reset the LTFTs. Any truth in that?
Thanks much.
Scottydoggs
NJ
pulling the battery for 30 minutes resets the whole pcm. so all systems would need to re learn and pass the internal test to become "ready".
a large vac leak would have set a lean code by now and your trims would be +25.
Mudsport96
40.923,-89.488. Illinois
Is this driving/ under load? Or are you in park just revving? All data points need to be taken in a real world scenario, i.e. driving. Long terms are a bit high, but the computer is always trying to get to its programmed fuel mix. So if it was "seeing" lean exhaust, it would add more fuel. So if the O2 sensors were shot, and it was overfueling because it thought it was lean the trims will be high.
2006Tahoe2WD
Silicon Valley
Agreed. The STFTs are way too good at idle to have a larger sized vacuum leak.
Somewhat agree. Whatever vacuum leak (small) and/or fuel not getting fulling delivered this has been now compensated by the LTFTs leading to the STFTs to be rather close to zero.
Agree, if I had a "big" vacuum leak there would be a code by now and or the STFTs would be high (~20%) trying to get to the proper a/f target.
Mudsport - If you want me to post STFTs and LTFTs while driving on the highway - I can do that. The last time I did that the LTFTs were highish - ~10% and the STFTs were lowish <5%.
Some of you out there have a scanner. How about posting what you actually read for LTFTs and STFTs at idle and e.g. 2000 rpm to start with.
Also, I disconnected the battery for one hour and it didn't seem to reset the LTFTs.
2006Tahoe2WD
Silicon Valley
Mudsport - here are fuel trims at highway speed about steady 60-65mph on the flat.
I tried to hold a steady speed and throttle position to stay in one "cell" of the fuel map.
I would really like to see what others are getting - e.g. are you getting under +/- 3% LTFT?
I bet not.
@mudsport may not see your prior post (now that I tagged him he will be notified). In your post use the "@" symbol and start typing his username, then pick it from the list; that'll notify him that he's been mentioned. Either that or use the "Reply" button to quote his prior post in your new one. Keeps the communication connection.
2006Tahoe2WD
Silicon Valley
ah, okay will do.
2006Tahoe2WD
Silicon Valley
I'm not trying to cause controversy. Tempting to reverse engineer the algorithm to some extent. E.g. When and what sort of data ends up affecting the LTFT? There are a thousand nebulous opinions on the web. Maybe we can make some headway to a better understanding.
Scottydoggs
NJ
the ltft and stft are the engines fueling. many things can affect the fueling. exhaust leak, vac leak, needing a tune up real bad, dirty injectors, stuck open injector, clogged cats, to even bad high mile o2 sensors that have yet to be bad enough to set a code. truth is, your trims look fine to me. id just carry on.
2006Tahoe2WD
Silicon Valley
Agree but I may have figured it out. Something is going on because it is not zero.
@Fless mentioned something that came back to mind. I see a very consistent 9-12% LTFT values across all the driving conditions I use when on the throttle. I wonder if the base fuel map was originally set for 0% ethanol? Considering 2006 or our range of vehicles I would guess the base map would be assuming 0% ethanol. Most all the country including CA use 10% ethanol now - some states have E85. THIS would account for 4.7% of the positive values of LTFTs I see. Ethanol makes the engine run lean without a correction. Also I read that when resetting LTFTs it is a good idea to unplug or turn off the purge valve. The purge valve runs much of the time when off idle (air coming in = lean). So at this point I'm thinking the root cause(s) of "high" LTFTs:
- 10% ethanol
- purge valve active
- misc. small vacuum leaks
GM knows this and CELs are not set until the LTFT go way above 10%, exactly what that number is I don't know.
What do you think?
Having an open purge valve brings in fuel vapors, so the mixture would get richer. The O2 sensors would read that and the PCM would adjust. I forget -- how old are the O2 sensors?
I'm curious if you have a physical alcohol sensor. Either way, it would be interesting to:
1) reset the LTFTs and monitor them over time
2) read the current fuel alcohol content as determined by the vehicle, using an advanced scanner
3) compare that to the fuel you've been buying
3a) if they don't compare favorably, reset the alcohol content
4) sometimes there are revised PCM "calibrations" that can be updated; a shop with access to GM programming could read yours and advise if an update is available. There may be one that updates the alcohol content algorithm.
You could also consider using ethanol-free fuel for a few tankfuls, as a test, and if it's available in your area. Monitor the trims using that fuel.
Scottydoggs
NJ
you will never see a zero trim. ever....... they are always moving.
install a wideband sensor. not cheap but you'll for damn sure know if your afr is right or not.
2006Tahoe2WD
Silicon Valley
The purge valve will pull vapors initially but soon should be almost "clean" air as the charcoal "dries" out. That's my understanding but I haven't seen any data on that.
My 4 O2 sensors are new, MAF is cleaned but not assumed to read correctly but does show expected data. The air filter was only slightly off color, no debris. Connections have been triple checked but there may be a crack somewhere.
There was an explanation regarding alcohol sensors. Apparently there used to be a sensor and then they did away with the sensor and used the O2 sensors and a few tricks to estimate the alcohol content. I don't know if this was for flex fuel or the "regular" fuel versions. I think there is also an alcohol reset but I don't know if my scan tool can do that - after I get it running again.
Additional info that I failed to post. During idle - I only have about 4-5% LTFTs - which supports my hypothesis. I would need to double check or unplug my purge valve to confirm to some extent.
A theory (matches what I see on my Tahoe):
Idling - only the alcohol adjustment is in play (LTFTs are + 4 to 6%)
Normal Loads - 10% alcohol offset and purge valve are in play (LTFTs are + 9 to 12%)
2006Tahoe2WD
Silicon Valley
I expect the O2 voltage to swing back and forth across zero (~14.7 or whatever it is going for). The controller must be also swinging the injector timing - I would expect to see the wideband also swing but it might look like a ripple and not 0.1-0.7-0.1 back and forth.
2006Tahoe2WD
Silicon Valley
In other words - Yes, you will never see the STFTs being steady - they will always swing along with the O2 sensor outputs.
BadDaddy2003
