latvius
Ariton Alabama
Did you try fitting it in your Denali with the cutouts facing towards the front of the truck? It is offset a bit to one side (I received mine today).
Yeah it is not even close to fitting. The Denali cup holders are much smaller than the Tahoe.
Roilux
Senior Member
Burbank, CA
A 'crystal ball' arrived today for my trusty Tahoe that included a pleasant surprise.
I purchased HPTuners MPVI3 interface (no credits) through Amazon to access a 6% purchase credit. On the box is a 10% off code when purchasing credits, of which I'll need two. :gr_grin:
5x10
Was mowing my grass, facing my Escalade, my mower discharge shoots to the back right , I’m about 15 yards from my car and i see all the black glass drop.
‘odds are , a rock was discharged and hit it, but I don’t see how it got the angle
ScottyBoy
Shreveport, La
My Father in Law did the same thing, not once, not twice, but THREE times! He has a rock/gravel driveway and he had the discharge chute on the mower pointed towards the house. The driveway is a good 20-25 feet from the house, but thats still close enough to shatter a window twice, and most recently the sliding glass door. It's the double oane glass, and he shattered the outer pane on the window and left it like that until he shattered the inner pane. He shattered the other pane on the sliding glass door and it currently has only the inner pane. His response was "I still have one more glass to break before I have to get it fixed." I told him to either use the push mower when cutting along the driveway, or to make damn sure that the discharge chute is facing AWAY from the house when using g the riding mower.
5x10
That’s the crazy part, the discharge wasn’t pointing towards the car, it’s discharges to the back right and I was facing the back of the car and saw it shatter. I always discharge away from the house
S33k3r
Dallas, Texas
I had a back glass shatter from a windstorm with no rock. The glass is typically 20 years old. It may have just, finally, lost integrity and shattered.
5x10
I’m think that when I drove the other way, a rock could have hit it, and it didn’t fall apart until I turned back around
either way, it’s a b*tch trying to find Replacement , looks like I’m going to have to go used, $319 from lkq, shipped to the one near my house
called safe flight, they quoted $1500 but don’t seem to have one available
called a few local guys and none can track one down
one guy is asking if I’m ok with a suburban one
Burban22
What’s the best front center console cup holder insert or complete replacement for 03 GMT800 suburban? I keep tipping standard size drinks in these oversized rt44 / rt66 big gulp holders that came standard.
mountie
You can also remove the inside insulation-insert, if needed. They fit perfect in the cup holders. Also, a regular 16oz bottle of water fits nice.
S33k3r
Dallas, Texas
Check Craigslist and FB Marketplace. We have those things on there ALL the time. You do have to be quick, though. They go really fast (when the GMT800 no longer does... :()
project_x
I'm looking for a pig tail/connector for the roof harness that connects to the lift harness... Mine is burnt...
I've seen the work arounds. But would prefer to replace.
Any ideas?
mountie
Got my motor out, now i got to clean everything up before i stuff the new one back in.
View attachment 425917View attachment 425918
I replaced a Northstar V8 in my '93 Cadillac STS ...... I cleaned, and MORE IMPORTANT, I heat-shielded as many fluid lines & wire harness runs, as much as possible, when they were close to anything that got hot. ( It was a great engine!) I felt so confident, when I protected all the stuff.
D Rollins
