Right front wheel protrudes further than left?
GMT800 2005 Tahoe Z71
Navy Supporting Member
If the rotor was machined wrong (i.e. too thick where the hub is), the studs would not stick out as far. If the rotor was too thick there, the wheel would stick out further.
Yea, called the "rotor hat" thickness. If it does not matter what wheel is there, well.....it is baffling as to what is wrong. You could take to a trusted alignment shop of a body shop that does frame straightening and have it set up and get some measurements.
vcode
Just curious, can you take a measurement from the frame to the seam weld (or something easy to measure) under the rockers to see if that is the same side to side?
Foggy
KS
I would just put it on an alignment rack and take measurements
1/4" is really not that bad as long as tire wear etc is good.
It could just be that your aftermarket wheels are a bit off or the
difference in tire sizes from OE are giving you the "scrub" concerning you
Or that when brakes or wheel bearings were done in the past that
the hubs/wheels/ etc were not all cleaned the way they are supposed to be
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I would pull the front wheels, throw a few a few lugs on to hold the rotors snug and take some frame to back of rotor measurements to compare.
KidWgn
KidWgn
Certified Kid Hauler
St. Louis, MO
This is the 4th set of wheels that's been on the truck. 3 OEM sets, 1 aftermarket.
KidWgn
KidWgn
St. Louis, MO
I'll be on an alignment rack Tuesday, so I'll measure everything then!
JasonW4141
