Rattling metal sound while acceleration
DmitryGMT800
Baku, Azerbaijan
Hello everyone! I would like to share my problem. A metal rattling sound started to appear while accelerating. It seems to disappear (or is probably not so clear) while on higher speeds, but when starting off the traffic light it is clearly audible. Some noise can be heard while sitting on traffic light with foot on brake. No noise while pressing gas pedal in Park. I have added links to videos with sound.
rattling noise
rattling noise
02 Tahoe 5.3 4x4 / 400 000 km.
Had starter solenoid replaced by one off Escalade 1 year ago, due to not starting. I suspect the starter gear does not retract fully or wobble freely and thus hitting the flywheel. However, this does not explain the absence of sound while in P.
Had gearbox overhauled with a kit and additional parts after losing 3rd gear 1 year ago.
Any ideas where to dig before I visit the shop?
Thank you!
rattling noise
rattling noise
Thank you!
Get under the truck with a rubber mallet and start smacking around, heat shields are the most common culprit, there is one on the side of the transmission and one along the side of the drive line by the gas tank, one by the spare tire and maybe one on each catalytic converter, maybe one around the starter.
if it is one of the bolt on ones tighten it up, if it is on a cat then have it welded
D
DmitryGMT800
Baku, Azerbaijan
any vibration? u joints click when bad. if its a 4x4 put it in 4 high, see if it vibrates. front axle might be worn out.
No vibrations at all. Put it in 4x4 modes - same noise. Just tried the reverse - no noise when moving, but upon coming to a full stop - there is same clunking noise for a couple of seconds. looks like starter interferes with flywheel..
Welcome to the Forum from NH.
Pics of the truck, please.
Put the truck on a lift and raise the truck up while on the lift, so that you can put it drive with the wheels freely rotating in the air. Then go around under the truck and locate the area and source of the noise.
D
DmitryGMT800
Baku, Azerbaijan
Thank you!
I am following the advices. Will update on what i discover. Attached are some older photos of my rig
D
DmitryGMT800
Baku, Azerbaijan
Update/Solved: Starter solenoid was causing the weak retraction of the gear, so it were touching the flywheel teeth. Solenoid replaced with a new one from Hyundai:Big Laugh: They seem to be the same construction - fits just right. Only difference was the plug connector on new one instead the bolt-style connector on the old.
Hope this may help in case one does not have access to right parts. Problem solved! No more grinding sounds!
Will order the whole starter assembly though, as the starter had plastic parts inside that broke into pieces while assembly.
Thank you all for assistance!
D
DmitryGMT800
Baku, Azerbaijan
There is another issue I have found while under the vehicle: two bottom bolts that fasten the gearbox housing to engine (the oil pan area) are spinning freely - the gear box guys must have over tightened and stripped them. What may be the outcome of this insecure connection and how i may repair the threads? I think using the thread insert may work.
Thank you for posting your solution to your issue. Our collective knowledge base has been increased.
This has been discussed in previous threads. @OR VietVet ; @Doubeleive ; @wjburken ; @Geotrash
gearbox? pictures would probably clarify unless this has been converted to manual there is no gearbox... wrong term
wjburken
Eastern Iowa
Transmission translation issue, I believe. If I read it correctly, he is either referring to the bottom bolts of the bell housing or the two rear bolts that tie the pan to the rear cover. I've seen where folks have stripped them out, but usually its the rear pan bolts and not the bell housing bolts.
As already asked, if you can get a photo of the particular bolts, that will help eliminate translation issues. Either way, putting a Heli coil in may be your best option based on my understanding of what you have shared.
GMT800 2005 Tahoe Z71
Navy Supporting Member
I agree with the heli-coil fix. I am not a fan of them, PITA, but when done right, they work very well. In other words, if you do the heli-coils, patience and good operating correct tools and know how, wins the day.
Towmaster
