What does the blue connection do?
L
ls1frc
Starting to think I just bought the wrong head unit for what I wanted. I wanted to play stuff to the rear screen while having carplay up front. This doesn't have anything to switch any A/V outputs to different zones.
L
ls1frc
Okay confirmed it doesn’t have dual output but I don’t really care about that because it allows display to the rear screen while having car play up front
I simply had to use the av in and not the hdmi in
L
ls1frc
CarPlay in front and my laptop to the middle screen
I will just need to wire up the rear screen now and I think I’m good with this head unit it fits my needs
L
ls1frc
Getting closer but
Now fighting static noise issue even with volume all the way down
L
ls1frc
I think I forgot the amp adapter that comes with the harness.
I swear my engine swap was easier than all this
L
ls1frc
Getting closer but
Still doing it even after amp adapter was connected. Does not do it with stock head unit. It’s not something I can live with so I’ll call around Monday for answers
are you using the factory wiring and amp? or did you add a aftermarket amp, etc.
L
ls1frc
Factory amp, I am just trying to do as plug n play install as possible so everything I bought just plugs right in. I used the maestro RR with the iDatalink HRN-HRR-GM2, iDatalink HRN-AV-GM2 and iDatalink ACC-HU-KEN1 (adapts the harness so it plugs right into the kenwood)
There's an AMP adapter it comes with to use with factory amp, I made sure that's connected.
usually that kind of noise is ground related, try running a seperate thicker gauge ground wire from the radio & module to the body somewhere
also double check your work make sure no bare wire is touching another wire or any metal surface.
once you have done the above and if the noise persist's try reaching out to idatalink and see what they say. It's possible they may have alternative firmware to try and see if it is related. or they may have other solutions.
L
ls1frc
Yeah I am thinking of just aborting mission. The Roku stick has all kinds of interference going through the a/v converter. It displays but you hear a constant audio noise in addition to the content that is playing
I am using an hdmi to a/v converter but perhaps the one I got is just crappy
L
ls1frc
Okay got this resolved. USB power isn’t enough for the Roku stick in the car. It’s coming through perfect now
L
ls1frc
Talked to idatalink. The voltage reducer is not reducing the output enough and since I just have an SLT and not a Denali the amp gain cannot be adjusted.
He said the only other thing I can try is manually splicing the wires into RCA front and rear
So I’d have to cut the plug and play harness. Worth a shot before I return all of it.
disable the ANC and it will sound better as well, it's possible you might be getting feedback from the anc already
also the headunit does not have a gain adjustment in the settings?
L
ls1frc
As far as I can see there's no way to adjust the gain through the software
I'll play with the ANC and see what that does
Bwaldron
