2019 Tahoe Torque Converter Replacement
TahoeEd
This is far to long, but if you are looking for a odd story, I'd like to know what you think. I know there have been a lot of conversations about the torque converters for various years, but I wanted to share my resent experience and see what the thoughts are here.
Prior experience with Chevy transmissions: The company I work for purchased 2 each 2017 Silverados and one of them was my vehicle to drive daily. From brand new I would feel a shutter when traveling around 35 mph to 45 mph at a consistent speed, but didn't think anything of it. 2 years later, the company purchased a 2019 Silverado for another employee to drive. Both of the 2017s had transmission failures before 100,000 miles and the 2019 has had the engine replaced as well as the transmission, in that order. In the 2017, that I specifically drove for 4 years before failure, the shutter ended up getting so bad the entire vehicle would shake and within 2 weeks the transmission went while driving down the interstate. No gears, only neutral.
Current personal vehicle background: I purchased this 2019 Tahoe Premier in November of 2022 with around 26,000 miles on it. With my prior experience I was cautious and tried to be very aware of what I felt while driving this vehicle. We drove it without changing anything until around June or so when I bought the Range AFM disabler. Prior to using the disabler I could feel the slight shutter (occasionally and only slightly) when in V4 at around 1100 RPMs driving consistently. If I accelerated it would change to V8 and shift out of the shutter. After using the Range AFM the vehicle has run great without the shutter at all.
Current situation: The vehicle now has 45,000 miles and the warranty for this vehicle is up within the next few months, so I bring it to the dealer to have a yearly inspection done and have them check the shutter situation so that if something needs to be done it is done under warranty.
First call from dealership: Yes we feel the shutter and the next step is to drop the pan to see if there are any metal shavings on the magnet and expect the torque converter needs to be replaced. They expected to see metal so they didn't want to drop the pan unless we could leave it there which we couldn't do as it's our only family vehicle. They then inform us to pick it up and bring it back once they have a loaner for us to use.
Second phone call back, same day: They tell me that the shuttering could be caused by the tires which are a little worn (but passed inspection fine) and it was in auto 4wd so that could have caused some of the vibration. I informed them that is not the problem and agree with their first assessment that the torque converter is most likely the issue. The person I'm speaking with agrees, but states he has to inform me of all the technician wrote down.
2 weeks later we call them about the loaner and their response was they were waiting on use to determine if we wanted to replace the tires, which we already told them we didn't. We then schedule to drop our vehicle off in a couple of days. The day after it is dropped off we get a phone call from the dealership saying their transmission guy drove it and says nothing is wrong. The vibration is from the engine and not from the transmission and only happens when it is going between V4 and V8 which is normal. An already too long of a story somewhat shorter, I tell them my experience with this shutter and after a long back and forth they agree to at least drop the pan and see if there is any debris.
The next day I get a picture of the pan and underside of the transmission with a message of everything looks normal, no metal, we are currently deciding what to do. A little while later I get a message they are going to replace the torque converter.
This all just seems odd to me, what did I miss here? if everything looked good, then why would they replace the TC? If the TC has to be replaced, should I then be concerned with the transmission or any other part associated with the transmission? Do dealerships typically replace it with the same original faulty TC or is there and updated TC now? This is something I plan to ask when we pick it up. I have posted the pictures they sent so you more knowledgeable individuals can chime in and educate me.
MobileHomie
45K miles should not be overextended for a trans service.
Trust your gut on this one friend.
From the crappy pics they sent, it does look like metal on the magnet and the fluid is more brown that red, indicting it its burnt. I bet is smells burnt too.
I don't know if there is an upgraded replacement torque converter or not, but most likely will be replaced whit the same part.
I don' know the years and models well enough to know what transmission is in your Tahoe, is it a 8 or 10 speed?
T
TahoeEd
I believe it is the 6 speed, but I’d have to check again.
T
TahoeEd
No, I don’t believe I need any specific information about the vehicle. I was more looking for opinions on what I should take from the conversation with the dealership. Yesterday they claim no problem at all and refuse to drop the pan. After persisting they agree to drop the pan but say everything is as it should be. Then they are replacing the torque converter. Seems like I might not be getting the whole story and want to know if I should be concerned with more potential problems. Do the pictures indicate anything other than normal wear for a vehicle with 45,000 miles?
Marky Dissod
Good. They are replacing the torque converter.
While they're at it, they ought to replace the ATF, which was not only overdue in my book
(I subscribe to Severe Service Intervals)
but wasn't there a TSB about the 8L90Es 'Chevy shaking',
and that the ATF should be flushed & replaced?
ComputernerdBD
Mid-Hudson Valley, New York
Just going to add a recommendation I just made in another post especially on the bypass valve, cooler and pan to keep your trans cool. My torque converter blew on Christmas Eve on my 2018 at 65k miles, shed a ton of glitter into the fluid and ended up turning into a reman transmission after having AAA tow it nearly 300 miles home. Luckily I felt the hesitation/slip/flare shifting and saw the temp rise and pulled it off the road. I have the Range AFM disabler adapter too and was checking to see if that had anything to do with it but discovered that was not likely.
The issue though unfortunately here is since you are already at the dealer (which can't blame as you are still in warranty) you are stuck with their runaround and also OEM parts with all of their flaws. Most good aftermarket transmissions come with a billet converter cover which addresses the design flaws of OEM with it distorting around where the three fittings are welded to the plate. I would insist if nothing else while at the dealer and if they are already into it they do replace the converter anyway with all of the fluid AND install the updated thermal bypass valve that opens at 158F to keep the temps down per their own TSBs recommending that happen with any transmission work and then once you get the truck back consider at least a transmission cooler now, aluminum pan when you do fluid again next time (this is probably excessive but I do my fluid every year but I also get away with that process easier as I don't need to do the filter as often given the pan drain plug). You might not need the Surecool kit if you get the updated thermal bypass but mine runs in the high 120s F on the highway, 130-135 in town.
With Auto 4WD I would suggest keep it out of there. Consider just shifting to 4 High if you are getting into snow or ice conditions but obviously not on dry pavement. Given your mileage and the nature of what they already need to do I would suggest have them do the transfer case fluid (If not already when dropping the trans). Your differentials too while they have it IF the price to do so is not more than comparable independent shops.
This is just from personal experience - I actually stopped using dealers years ago especially with the runaround, money grab tactics and poor/overpriced repairs on all three of my GM trucks, one of which could have turned into a fire with one of those repairs being oil cooler lines not installed properly. Before your warranty expires I would advise find a really good independent shop near you and develop a good relationship. That will go a long way to keeping your truck on the road and the costs and frustration of doing so much more tolerable.
Good luck and hope everything works out for you either way you proceed.
T
TahoeEd
I agree and will now be changing out the transmission fluid more regularly.
At one point during our conversation, before they agreed to drop the pan, they said there is a TSB for a flush and replace, but my vehicle doesn't meet the criteria because the "transmission guy of 40 years" says it's the engine shuttering and not the transmission. I would assume (I know, never assume) they would do that now that the TC is going to be replaced. I will ask if it has been done when we pick it up.
T
TahoeEd
I don't know how I missed your replay earlier, sometimes it's hard to read everything on my phone. Thank you very much for the suggestions. I actually have the updated bypass valve which I bought about this time last year, but did not install it because I didn't want to do anything the dealer could argue I voided the warranty. I think it is a great idea to look for an independent shop for future out of warranty work and will look around my area for one.
As far as the auto 4WD, this is my wife's daily driver and she drives about a mile to work and back. The day before we brought it in, the roads were very slushy so she turned it on. She forgot to turn it off before dropping it off at the dealer, but in no way is the vehicle run with it on very often. I just hate that it gave them another excuse for what could be the problem even though I rarely drive with it in auto 4WD and I'm the one that noticed the shutter.
Thank you for all the responses, I appreciate it.
NickTransmissions
Sin City
The transmission bench
That fluid looks like it has 345k on it...Shuddering is converter a lot more often than not. Replacing it is a giod call however the problem is that the dealer is going to put the same POS JMBX converter w/that stupid .022" converter clutch which gets worked to death, failing early and often.
If it were my vehicle, id yank the unit and go through it though i understand not everyone has the time or tools for that. At very least, flush all that stuff out, put all new fluid. Tell the dealer (assuming no work has been done already) to do the flush then take it to an independent transmission shop that knows these units. Let them look at it, those pictures and they will give you their opinion on what next steps should be. If the TC is replaced, make sure they install a converter with a .070" thick Borg Warner high energy converter clutch. Then have them flip the pill on your TBV, per computernerd's post.
If all this has been said already (i didnt read responses posted after your reply to me), consider this positive reinforcement.
Quote my post or mention me if you reply; I had no idea you had initially and just happen to see it just now while scanning the forum.
T
TahoeEd
Thanks @NickTransmissions, I greatly appreciate it. What should I look for in an independent shop? We have a local shop that services our company trucks, but he’s not a transmission specialist.
NickTransmissions
Sin City
You're welcome. Ask around, including your local shop; also check Yelp and other local service / product review sites or even Facebook/Linked-In. The shop that works on your transmission (or vehicle, for that matter) should possess three attributes:
1. Sufficient body of knowledge of the transmission you'd be bringing to them for overhaul, including how to systematically inspect, test and diagnose to identify the specific reasons for your transmission's failure
2. A validated, proven rebuild strategy for the unit (i.e. they know exactly what parts to replace, procedures to perform, pattern failures to address and corresponding updates to make to prevent recurrence of the same or other problems
3. Willingness to work with you, meaning they patiently answer your questions as well as ask questions of their own about how you currently and/or plan to use the vehicle, vehicle/trans service or repair history and goals/preferences (i.e. what's 'success' mean for you when it is all said and done).
See my 6L80 Info thread (if you haven't already) for more details around parts, procedures, common problems and fixes, etc - link is in my signature.
BMPNUGLS
Mid-MO
I recently dropped the pan on my 2016 Denali XL with the 8L90 at 145K miles….it previously had the fluid flush/replace with the updated fluid via the dealer under my extended warranty at ~70K…so pan/filter had not previously been replaced….my magnets at 145K did not have nearly that much stuff on them! Which was a bit of a relief for me since I’ve been concerned about the transmission life.
I installed the thermal bypass at the same time I dropped the pan (as well as replaced the solenoid/temp harness because it would give me a code once in a while)….now ~15K later transmission feels better than it ever has and never gets above ~125*. I also have had the Range AFM disabler installed since almost day one when I bought it new.
Just my $0.02…frequent (more frequent than I initially did) fluid and filter changes and the thermal bypass should let these transmissions last quite a few miles!
BlackBrud
Colorado
Just adding a note of support here. Bought my 2019 with 88K miles on it. I don't think the ATF was ever changed, so I dropped the pan, replaced the filter, and cleaned the magnet. The fluid was really dark and smelled burnt. I also added a full ATF thermostat bypass so it always goes to the cooler. I replaced about 5 qts of ATF during my first pan drop, and then I've since done one more drain and fill of the ATF with Amsoil ATF. In a month or so, I plan on doing my last drain and fill for a bit - I should have most of the fluid replaced by then. I'm hoping to keep it alive past 100K, and then hopefully one day I can take a trip to Vegas to get a nice build from @NickTransmissions .
I also replaced the fluid in both diffs and my transfer case with Amsoil fluids - might not be a bad idea in your case.
I hope your issue gets sorted quickly!
arkie
I also have a 16 Denali, and would love to know the details on your trans mods. Can you DM me the part numbers you used?
T
TahoeEd
Thank you for all the input.
They ended up installing a remanufactured torque converter and did a complete flush and filter change. I had my wife ask if they replaced the thermal bypass when she picked it up. The answer was less than encouraging. The person she spoke with (I assume he is a go between for the customer and the technician and not a mechanic) said they reprogramed it and it will learn your driving after a few miles. This is also the person that said there was no metal and everything looked fine.
I spoke with my local mechanic and he gave me a couple of names he would trust with a transmission, so I will reach out to them and just have a conversation on what they think should be done next. I will at least install the updated thermal bypass I bought last year and continue using the range device. I don't really have to worry about voiding a warranty as the powertrain is up in a couple of months and the remanufactured torque converter only has a 12 month 12,000 mile warranty.
Fifty
@NickTransmissions
I’ve been trying to find a trans shop that is familiar with the 8l90 for about 2 years.
I’m in the east bay area of California
No one.
SoCal yes, but that’s a 14 hour drive each way.
Can anyone recommend a shop in the Bay Area? My 2015i has a 2nd gear flare when it’s cold and the shutter.
44k on the clock.
It needs to be gone through. I figured a converter and a rebuilt trans. I don’t want any more issues and I want to be able to run 35’s off-road eventually.
Drewphil
