Inherited 99 Suburban
1968charger
1968charger
1968charger
1968charger
I am going to recover the front seat bottom I see leather covers are available from at least 2 different companies. The heated seat does not work. I think the lower element is bad. Is 12475772 the correct part for the bottom element? I know its disconnected. Is there an aftermarket option?
If you want high quality OE-style covers try The Seat Shop https://www.theseatshop.com/. They also have new Durofoam cushions, but I don't know about seat heater availability. They're not exactly cheap, and there are other alternatives elsewhere, but they are great quality and their videos are very helpful.
Welcome to the Forum from NH.
east302
Mississippi
First jobs are a new radiator
Welcome to the forum!
Heads up on radiators. Some aftermarket radiators include an unused port under the cap that GM did not use on 96-99 trucks:
I think the port was used on some of the earlier (88-94?) trucks. As the radiator is meant to be “universal” and fit those trucks, many companies put a rubber cap and hose clamp over it. Often, these are low quality vacuum style caps that degrade in a few months and leak or fall apart.
Here’s one:
While you can replace the caps with a silicone cap that is more resistant to heat, the better option is to find one that either doesn’t have the port at all (GM still sells them)…
…or has a threaded plug instead
BadDaddy2003
