2007 Tahoe/New lifters now no tahoe won’t start
Jessemas23
Just installed new lifters in my 2007 tahoe today on the passenger side and after I get everything back together the Tahoe won’t run. Starter will clunk and a I may get it to turn over a time or two but will not crank. Turned crank by hand and it is very hard to turn. Any suggestions?
strutaeng
Dallas, Texas
Remove all of the spark plugs and try to spin the engine by hand. Engine IS going to be hard to turn. With a 12" long ratchet on the crank pulley bolt there will be some resistance; that's normal.
Double check all of your wiring if you removed anything. What else did you replace? Maybe pushrods? You didn't replace the cam, did you?
Just removed the head on that side and the lifters? What's the history with the truck? How did you get here? Give us some background. Was it running okay or decent before?
wjburken
Eastern Iowa
Along with what @strutaeng asked, how far did you tear into things to replace lifters?
On a similar note, when I replaced the cam and lifters on the 6.2 in my 2007 Yukon, when I went to start it up, I got nothing. After going back over everything that I had apart, it turned out that my starter seized up on me while I was waiting on parts and time to do the work. Completely unrelated to what I had worked on.
Go back through and check ALL your wire harness connections, sensors, etc. first step in Troubleshooting is to review whatever you just touched so go through all of that.
J
Jessemas23
I bought the truck around 2 months a go knowing it needed lifters on driver side. Replaced lifters, head gasket and head bolts. Everything was working fine until I drove 800 miles from Tennessee to Florida where I developed a lifter tick in Cylinder 6 on the passenger side, pulled valve cover and discovered a loose rocker arm. Pulled head on the passenger side to replace the lifters and everything seemed to be going smoothly until I got everything back together and no crank, turnover very slow… almost fast enough but not enough. Just installed a new battery and alternator yesterday. Now I’ve tried cranking it so much I had a small fire from the bottom of the motor
Removed the passenger head, huh? That's where the main ground for the battery goes. Did you put it back, along with the other small ground that goes on that stud? Was the metal clean underneath it? Perhaps the cable is corroded on the inside where you can't see it and removing and reinstalling it weakened it further and now it won't carry enough amperage for the starter.
wjburken
Eastern Iowa
In addition to what @iamdub suggested, I would at least pull your valve cover off and make sure your rocker arms are good and were put back correctly. With a loose rocker arm bolt, it may have had one came loose and not letting a valve open.
mikez71
Does it crank faster with the new batt?
J
Jessemas23
I’m assuming from the starter
no it doesn’t,
j91z28d1
a small fire under the engine? I'm guessing passenger side?
if so, you melted down your starter and it's going to need replacing at this point. even if it's not your first problem.
J
Jessemas23
Quick update, I believe I didn’t have one of the non afm lifters positioned properly in the tray which was causing the lifter to bind under the tray. Anyway tore it apart, fixed lifter alignment, reinstalled everything(along with a new starter) and all is well.
wwiizz
